Wiper blade recommendation.
mountaindude
My tercel:: 1984, 1985
Post by mountaindude »
My 84 and 85 both have what is referred to as "bayonet" style wiper arms. The brackets for the wiper blades that I find at Wal Mart, simply break, freeze and break, or just fly off.
Lost both last night in a snow storm. What good quality wiper blades do you recommend for sub zero, harsh Winter conditions?
Re: Wiper blade recommendation.
the Boshe work well, but are costly. there are better quality blades that usually have a higher quality arm and mount as well, I like the composite Teflon blades, I do not remember the brand, but it is their upper line (more expensive) blade. It lasts much longer too.
mountaindude
Thanks. I don't mind paying more. Having the Wal Mart offerings fail during a near "white out" was awful.
Hiro
My tercel:: 1986 Toyota Tercel FWD 5spd
Post by Hiro »
I usually rock auto mine and try to stick with Bosche or Trico. For the price of a set at Advance Auto or walmart, I can usually get 3 or 4 good sets shipped from rock auto, which usually last me 2-3 years. Apparently, you're supposed to replace wipers around ever 3-6 months anyways... I go until they start streakin...
You get what you pay for, but at the same time, you can still save money if you look for the closeout and clearance deals for the same rock auto stuff. The clearance ones still have good rubber on them; unlike my skeptical friends, I've not had a bad lot of blades or oil filters from rock auto.
'86 T2 DLX (114,000 miles and counting)
'90 EE4 RT4WD
'92 EG VX Hatch
'95 YJ 4.0L
'05 C6 Z51 (460rwhp)
3-6 month replacement blades? sounds like junk.
We really need good wiper blades here in the PNW, and with the gravel roads I drive daily we pick up a lot of fine sand and silt on the glass, particularly after a long dry spell (about 3 weeks for this area). I have found the Teflon composite blades last about a year if I clean them off regularly (wipe down with rag and soapy water, and use silicone or armorall on them). I too have had blades fly off the arm in the middle of the storm (it flew off into road side brushes and a ditch...spent too much time looking for it and gave up), so the cheap attachments I am leery of as well.
I have tried to just replace the blade itself, and reuse the arm assembly (which is better quality on the higher priced blade assemblies), but the pivots wear out and they get sloppy (particularly after a year of heavy gritty use). So I find it is just as well to just replace the whole arm assembly with a the new blade already in it.
One time I bought in a clearance sale some techie looking double blades (in Red, for my black pathfinder, just to dress it up for fun), and to my surprise it not only worked exceptionally well, it also lasted longer. Though it too eventually wore out and I did not want to pay the full regular retail price, so I went back to the regular quality blades. likely you can get some decent ones on ebay or Amazon at a good price. These did some serious window clearing in heavy rain, snow and ice. the only ones I could find were on alibaba, so not sure of quality, though Autozone says they sell something similar.
looked like this:
Hiro
Post by Hiro »
Petros wrote:3-6 month replacement blades? sounds like junk.
Sorry; you might have misread my comment. I was restating typical service intervals for wipers. Kind of like how some cars have 25k mile service intervals for tie rods. Sure they may not work as well as new, but they aren't bad enough to be a safety risk or justify money to replace...
Life of blades will vary from environment to usage to care. Running wipers on a dry windshield will wear out faster. Pitted windshields with cracks or chips will eat up wiper blades. Low humidity and high temperature environments dry out blades. Sitting in direct sun dries them out. Etc. I usually get 6-9 months out of lower cost blades, but I'm okay with that because I spend significantly less over time than a good set of blades that last 9 months or longer. If the lower cost set works equally well as a higher cost set, but requires replacements 30% more frequently but cost 80% less, why pay more? This is what works for me, but I understand it may not work for everyone :)
'90 EE4 RT4WD
'92 EG VX Hatch
'95 YJ 4.0L
donnyre
My tercel:: 95 Tercel
Post by donnyre »
I can say that Bosch wiper blades are worth the price. Not noisy, and no streaking.
I buy replacement wiper "inserts" (refills?) and have been using them on replacement 18" blades I installed in 2005. The inserts are getting harder to find, however. I replace them in the Fall and again in the Spring. The last pair was $8.00 at AZ.
Tom
Post by splatterdog »
Gets harder and harder to find wipers with screw on mounts. The push on ones do like to fall off. I usually go cheap/replace often on blades.
Our first winter blast I saw a "guy" pulled over and it looked like he was calling someone for help. The problem- a flipped wiper blade! Send help!!!
MotorLicker
My tercel:: 1985 DX 5dr 2WD
Post by MotorLicker »
I'll add to the echo chamber and say Bosch!!
Bought a cheapo pair from lordco this winter one flew off on a bridge during a snowstorm which was pretty interesting. Luckily I still had the old Bosch to put on. Better to have a streaky old blade than one which flies off randomly.
Hope you weren't on the Port Mann bridge. The ice bombs that fall off of that one could easily take out a Tercel!
