"The Nomad" my 84 sr5
timothygodden
Re: "The Nomad" my 84 sr5
Post by timothygodden »
Petros wrote: btw, all 16 valve heads may not do this, I think the early 4age have the same rear to front flow as well.
Wow so lots of different choices for the 4age head gaskets, with all the different 4age hybrids out there, I am really surprised there isn't more readily available information on this. I have seen 20v compared to the 16v but not the various 16v compared, does the 4agze have a specific gasket as well. What do the 7age hybrids use?
I always thought that tha a 7age would be a nice swap for the tercel same crank bolt pattern, better torque then the 4age, and a lower red line then the 20v.
there is no proper 7age, there is a 7afe that might be too tall to fit without a modified hood. the "7age" is a 7afe short block with the 4age head made to work on it, it was never a production engine, but something the backyard builders came up with.
The 7afe is not a bad engine for the TErcel4wd, if it could be made to fit. It has a remarkable flat torque curve, lower rpm and excellent economy. making it fit might be a lot of work, and I do not know if they ever made one designed for a conventional front to back installation, so either you would have to plumb the radiaor hoses to work, or experiment with reversing the flow in the head.
