* these springs cost around $24 from JCWhitney or could find elsewhere?
* notice the closer windings at the ends of the spring...meaning that they are progressively wound springs...and that the spring will collapse easier under a lighter load...until the end coils are pushed togeher
* the clamps supplied are not that heavy and the torque on the bolts is supposed to be limited to 40 inch pounds to avoid crushing the shock
* the lower clamp sits right above the weld at the bottom of the shock and so should hold OK
* the upper clamp is a different story...especially due to a partially rusted shock dust cover at top
* so I used a section of 2" OD exhaust pipe over the top of the shock and an old Toyota rubber exhaust hanger to cushion it at top...this prevents the top clamp from sliding up under a heavy load
<span style='color:blue'>Later note: found that the surface that the top of the 2" OD exhaust pipe rides on...where the shock bolts in...is slightly tilted off perpendicular...so if the end of the pipe is cut straight across, it causes a sideload on the spring and thus the shock. So....the top end of the exhaust pipe MUST be cut at a slight angle in order to avoid this side load.</span>
* the rubber sleeve around the top of the shock was cut and custom fitted using vinyl tape.
* right above the brake drum, you can see the "saddle" boosters that originally boosted the rear springs by around 1/2" (and still do)
* got an additional boost of only around 1/4"....this is probably due to the progressive winding of the springs..car does feel stiffer in the back and will likely sink less with a serious load
* so far they make no noise
* the 1200 lb springs would probably be a better bet? Use the ones for the smaller shocks...they are the same 14" length. There is about 2" slack adjustment if these are too strong of a spring.
With new rear springs + these boosters, the 750 lb ones would be better?
* to install...just remove the lower shock bolt and pry the shock from the stud...pushing the shock UP allows getting the spring on easier
* as usual....I used moly grease on all assembled metal parts
>> Used these booster springs during a camping trip with some offroad mud and sand running with 600 lbs total in the car...they kept the car level and held up thru this trip. Had them shimmed so they boosted a little more than is shown in the pics though. <<
