1984 FWD abused
- My tercel:: 1984 FWD DLX
1984 FWD abused
Well not sure how much interest there would be but I've been working on a project Tercel.
I bought an abused 1984 FWD auto trans 4D Wagon DLX. It was apparently used on a deer lease, and was probably going to be scrapped soon if I hadn't bought it.
It came with an array of problems including overheating, broken strut mount, camo spray paint job, trashed interior, dents and holes in the outside. And of course title issues.
I have not worked on cars before so this is meant to be fun and help me learn.
So far, I have removed all the seats, replaced the broken strut mount, replaced thermostat, worked a lot on cleaning but there is a long way to go. A lot of purple tint to remove. For some reason, the two front seats have been replaced with ones that only fit in 3 out of the 4 bolts. Spark plugs and oil are ready to go. I also began sanding down the paint to redo it in one color.
Overall it is a mess and doesn't seem to fit in next to all the pristine 4WD Tercels. So, are FWD Tercels welcome here? And dirty dented projects? I can post pictures if anyone would like to see.
Thanks
Thanks
Re: 1984 FWD abused
Welcome!
Of course 2WD's are Welcome!
They are just a sibling to the 4WD's!
To paraphrase Gertrude Stein - "A T-Wagon is a T-Wagon is a T-Wagon!" I will add: Regardless of drivetrain!
Re: 1984 FWD abused
I only have a FWD wagon at the moment!
Re: 1984 FWD abused
very welcome. post pics!
Re: 1984 FWD abused
welcome!
sounds like a big project. we can assist you in just about all of your repairs, most of the systems and parts are the same as the 4wd version. one word of caution: if you are doing this for fun and your own entertainment/education, that is fine, but the fwd version of these cars does not have much resale value, so do not expect any return on your investment if you plan on selling it later. Though most of the cost will be labor, which you are doing yourself, it is a lot of work to do for free if you have plans to sell it later. OTOH, the 4wd is very desirable and good running examples are getting remarkably good money for such simple little 4wd econo-boxes form the '80's. The 4wd version is worth fixing up if your plan is to resale it later when you want to look for another project car.
welcome again and good luck.
- My tercel:: 85 Tercel 5dr FWD
Re: 1984 FWD abused
I don't have the 4WD either. Mine is the hatchback version so I don't even have the wagon! The folks on this forum have never once held that against me or made me feel like my questions or car weren't worth helping.
Seriously, you'll be hard pressed to find a more welcoming and helpful group of people on any forum on the Internet.
Good luck with the project! If you haven't yet, check out the Service Manual you can download in the FAQ thread. Between that and the group of Tercel gurus on this site you'll be able to tackle any issue on these easy to work on cars.
1985 Tercel 5dr Hatchback
2003 Chevy Suburban
2014 Ford Flex
2003 Chevy Suburban
2014 Ford Flex
Re: 1984 FWD abused
Thanks everyone! I appreciate the posts I should have known there was nothing to worry about.
And I definitely won't be profiting, I have spent a good amount on parts already but it's more about the learning experience. The car is beat up and I do plan to paint it myself with Rustoleum at this point. There are some amazing looking 4WDs and Tercels on the forum for sure though!
Currently mine only has 1 seat inside and I've begun a very long process of sanding the paint down to silver/primer while trying to figure the car out mechanically. I probably need to slow down a bit and research more but it has been exciting to learn and work through problems.
Here are a few initial pictures of the damage..
http://i.imgur.com/vMkTa0S.jpg
http://i.imgur.com/iD05ieG.jpg
http://i.imgur.com/PGTdNMi.jpg
http://i.imgur.com/M6l5qz6.jpg
http://i.imgur.com/OwANVVI.jpg
Re: 1984 FWD abused
that is a great paint job! but if you do not like it, bad paint is an opportunity to turn it into an "art" car. pant any way you want!
Re: 1984 FWD abused
Progress is slow but the car is improving. A lot of parts are discontinued unfortunately.. I need to find a replacement ported vacuum switch and may also need a wire and socket for the license plate light that's missing.
Replaced the radiator and need a new alternator. It will all be worth it once it drives..
- BaileySims
Re: 1984 FWD abused
that is not a ported vacuum switch, it is a TVSV (toyota vacuum switch valve, or some such name). it is vacuum switch that changes which lines get engine vacuum at different operating temperatures. during cold start, intermediate warm up, and normal warm running conditions.
You can still buy them on amazon and some other after market suppliers, there were lots of models of Toyotas that used them in the same years they still had carburetors. They are kind of costly, sometimes you can get them at close out prices.
It also might be possible to by pass it, you have to study each of the vac systems affected by the TVSV, and rig it to run without the temperature adjusted features. Mostly this is for cold start and running, after warm up it does not have any function.
Re: 1984 FWD abused
i haven't been able to find the correct type of TVSV's for a long time, on ebay, amazon, etc. there were a few on alibaba.com but that site is a scam. 4doorvip had his credit card # stolen after buying some TVSV's off of there. so new ones are tough to come by.
unless you're willing to shell out the $200 or whatever it is that toyota wants for the few they have left.
Re: 1984 FWD abused
dlb- Check out my post from a year and a half ago (I'd post a link, but can't- too stupid.) Just do a search on "MB switchover valve" and it'll come up. Sorry I never posted pics, but don't know how to do that either!
Re: 1984 FWD abused
is this the post you're talking about, rich?
viewtopic.php?f=3&t=4534&p=79567&hilit= ... ver#p79567
i remember you talking about creating a manually controlled TVSV so i assume that's the same one. you must post pics of it sometime!
Re: 1984 FWD abused
This makes sense.. and explains why I couldn't find it. I had an old school mechanic from Craigslist come look at the car and he helped out finding the vacuum problem. He also helped adjust the carb and get it to stop spitting black smoke! If it can be bypassed that may end up being my best bet, or perhaps just tying the broken piece on. It hasn't affected anything so far.
Is that the wire that goes into a clip on the hatch and into the plastic housing to light up the license plate? I would definitely buy that from you. I feel like I won't pass inspection without 2 lights on the hatch. I'll get pics up in the next few daysBaileySims wrote:I have an extra reverse light.
