parts in wa
Foryst
My tercel:: 1984 toyota tercel sr5 wagon 4wd
parts in wa
Post by Foryst » Sat Oct 03, 2015 3:29 pm
I have a bunch of interior and some mechanical parts for sale
-Cluster and housing (244xxx)
-Ps rack w/ tie rods
-Ps pump
-intake and exhaust manifolds
-Back corner windows
-Seat belts
-Driver and pass seats (driver has a few rips on bottom cushion, 83 blue)
-Radiator fan
-ac condenser w/ fan
-Glove box
-3a motor with Intake and exhaust manifolds attached (unknown miles and condition was told it worked but you never know)
-Internal regulated alternator (worked when pulled, my car is external regulated...)
-four doors blue on dark blue with all windows and interior panels attached (drivers door window doesn't go up all the way it's missing a couple teeth, was planning on putting them on my car but plans have changed sadly)
-Plastic molding covering e brake and the one that shifter goes into I forget what their called
-Grill
- windshield trim
-Dome light and trunk light housing (no light covers)
-Air filter housing (big black thing that goes on top of carburetor that air filter goes into drawing a blank on the name of it)
-window wiper motor
-Rear bench Seat and back support (83 blue)
-Set of four steelies with Toyota center caps( have tires on them but they are cracked)
-calipers
-Whole rear axel with diff.
-drive shaft
I have other interior and exterior parts just ask and I might have it. I pulled these parts of my last car after I crashed her and was planning on keeping them for my car now but plans have changed and their taking up allot of room I know other members would love to get a hold of them. Just shoot me offers as I am a cheap guy.
I'm not getting out of our tercels I just have to many parts built up, I still have all the spare parts I need :)
I want to deal locally so if your in wa I can make the drive
-foryst
The Professor
Re: parts in wa
Post by The Professor » Mon Oct 05, 2015 7:47 am
What color are the seat belts?
1984 Subaru Turbo-Traction wagon
1984 Subaru Turbo-Traction hardtop
1987.5 Subaru RX 3-door
Foryst
Re: parts in wa
Post by Foryst » Mon Oct 05, 2015 3:52 pm
The seat belts are blue all the parts came off the same car aside from the motor, 83 blue
BaileySims
Re: parts in wa
Post by BaileySims » Mon Oct 05, 2015 6:19 pm
Do you have that little boot that covers the bottom piece of the antenna?
WAGON MAFIA.
Blood, sweat and beers.
Foryst
Re: parts in wa
Post by Foryst » Tue Oct 06, 2015 4:39 pm
I do not have that i gave both of my fenders to a pal and it included the whole antenna I have been having trouble uploading pictures but you can see some of the stuff I have here http://seattle.craigslist.org/skc/pts/5255679297.html
Re: parts in wa
Post by irowiki » Tue Oct 06, 2015 6:39 pm
Do you have the two large trim pieces that go around the rear quarter windows and hold up the headliner?
81 Coachmen RV, 70k miles
95 Camry Wagon, 153k miles
04 Camry Sedan, 250k miles
The Professor
Re: parts in wa
Post by The Professor » Wed Oct 07, 2015 11:17 am
Where are you located? I think I'll go for the two front seat belts, assuming they are in nice condition. Pics of the parts?
Foryst
Re: parts in wa
Post by Foryst » Wed Oct 07, 2015 6:52 pm
I do not have any rear pieces besides the trunk light housing the rear end was totaled I'm surprised the corner windows made it.
The seat belts aren't in the greatest condition I'm sure if you cleaned them up they'd look nice. The belt clip on both of them are broken at the top where it would "loop" around but it is in all functioning order. Everything is there, my phone doesn't like me posting pictures on the site pm me your email and I can send it through there .I'm located in kent.
Red88
My tercel:: 1988 SR5 4WD WAGON:: 1984 SR5 manual:: 1985 SR5 manual
Re: parts in wa
Post by Red88 » Sat Nov 07, 2015 1:19 pm
Looking for a rear end with 3.73 ratio.
Got that?
Re: parts in wa
Post by ARCHINSTL » Sat Nov 07, 2015 6:48 pm
Front undertray/"rock guard" ?
Foryst
Re: parts in wa
Post by Foryst » Mon Nov 09, 2015 1:20 pm
I have the rear axel with 3.73 yes. I do not have the rock guard
new2yotas
My tercel:: 1983 tercel 4x4 sr5
Re: parts in wa
Post by new2yotas » Tue Nov 10, 2015 5:59 am
Howdy, would you happen to have a flywheel or ring gear for a 3ac ? im doing a 4age motor swap and would like to fit ring gear to 4a flywheel before I pull my motor..or the I.D. of the ring gear would be helpful.
Foryst
Re: parts in wa
Post by Foryst » Tue Nov 10, 2015 3:42 pm
I have a couple of flywheels yes. I usually get a new one when I buy a new clutch kit. I'm not sure what you mean by the ID of it but if you look up the kit, it will include a flywheel
Re: parts in wa
Post by Petros » Tue Nov 10, 2015 4:14 pm
his plan is to cut down the 4age flywheel to fit a 3ac flywheel ring gear, so he needs the dimention. Rather than send him the whole flywheel, take a torch or heat gun to the ring gear and pop it off for him, and just send him that. than the machine shop can determine the right size, just send the 3ac ring gear. saves a lot of shipping weight, and he only needs the ring gear. The flywheel itself is of no use to him.
See how to remove a ring gear here (I used a propane torch and it worked really slick, easier than I thought). https://www.youtube.com/watch?v=j_sgiTa3gew
jimcrazy
Re: parts in wa
Post by jimcrazy » Wed Nov 11, 2015 9:49 am
doen a 4a swap this winter, knocked the ring off 3a this morning the flywheel will have to be turned to 8.521", but after checking the measurments in order to get the ring gear back in the same spot on my 4a fly wheel the shoulder for the ring gear to sit on has to go back another .450,," doing this means the bolts to bolt the pressure plate on with will be 5/16" long that's not gona work, I will using the 3a flywheel on my 4a motor
