FS: 1986 SR5 Tercel4wd $1,800 manual in Idaho
sr-winter
My tercel:: 1984 Tercel 4wd
Post by sr-winter »
Not the cleanest body but it is an SR5 with working cruise control and Air Conditioning. The interior is in pretty good shape.
-170psi tested compression on all cylinders. Previous owner noted the head was rebuilt not long before. I did adjust the valves to find them all in spec.
NEW:
-Clutch with rear main seal, oil pan seal, etc
-CV axles (both)
-RF Wheel bearing
-Front shocks replaced with KYB
-Converted to WEBER 32/36 with manual choke
-RF lower ball joint
-Tires with alignment
-Front brake rotors and pads
-Salvania sealed beam headlights
sr-winter
Re: FS: 1986 SR5 Tercel4wd $1,800 manual
Post by sr-winter »
Gottolovem
Post by Gottolovem »
Where does this car live?
sr-winter
Post by sr-winter »
Southern Idaho, about an hour East of Boise
83623
sr-winter
Post by sr-winter »
bump
no offers? you want more pictures and/or videos?
can you post a pic of how you control the manual choke?
sr-winter
Post by sr-winter »
dlb wrote:can you post a pic of how you control the manual choke?
I just got this message, how does a video sound? it's cold this morning so it will be good to demonstrate
sr-winter
Post by sr-winter »
sr-winter
Re: FS: 1986 SR5 Tercel4wd $1,800 manual in Idaho
Post by sr-winter »
bump
