SR5 cluster swap?
Mac
Post by Mac »
anyone ever attempted or successfully completed an SR-5 cluster swap?
3A-C Power
Post by 3A-C Power »
It works, trust me it does
GTSSportCoupe
Post by GTSSportCoupe »
Mac wrote: anyone ever attempted or successfully completed an SR-5 cluster swap?
10min swap. Very easy.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
hey GTSSportCoupe...good writeup !!!!! :D :D :D :D :D
GTSSportCoupe
takza wrote: hey GTSSportCoupe...good writeup !!!!! :D :D :D :D :D
:lol: :lol: Nice sarcasm! :P
Mac, If you run into any problems, just post here and I'll give you some pointers. Other than that, if you have any mechanical ability at all, I think you'll find it really easy. I can assure you that the connectors are completely interchangeable between the SR5 and non SR5 gauge clusters (in the wagons anyhow). Just a matter of removing a few screws, unplugging the connectors, and installing the new one in reverse.
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Mac
Post by Mac »
thats good to know, my concers sprouted from the fact that on a non-SR5 equipped toyota, there was no wire going to the RPM signal sender on the distributor. running a new wire for the tach signal wouldn't be a problem, but i was worried about anything else like that which would cause headaches.
so i guess the RPM signal is all i have to concern myself with then.
thanks
ESI-RStarion
Post by ESI-RStarion »
bringing back a dead thread but where do I connect the new tach wire to/from? I'm not very good with electrical so any tips would be helpful!
83 T4WD SR5 - In tercel heaven
84 T4WD SR5 - (Rolled) joined the 83
83 T4WD DLX - Daily Driver weber 32/36, Celica/Paseo front brakes, 205/75/14 Snow tires, Lifted, 2.5inch exhaust, "Rebuilt" 3ac.
ESI-RStarion
Nevermind, everything worked fine when I plugged it in!
Mac
Post by Mac »
nice. I actually still haven't been able to find one at any junk yard, or here.
ESI-RStarion
neonsport has another one, I got mine from him. Not sure if he'll ship to canada but its worth a shot!
paradox11235
My tercel:: 1983 sr5
Re: SR5 cluster swap?
Post by paradox11235 »
What's the difference between the clusters? (non sr5 and sr5)
1983 Tercel SR5 4wd
1991 Audi 200 quattro 20v
1991 Audi 200 quattro 20v wagon
1975 Porsche 914 2.0
1986 Honda VFR700
larry mcgrath
Post by larry mcgrath »
sr5 has a Tac and clock
mrdance123
My tercel:: 84 and 85 4wd wagons
Post by mrdance123 »
I upgraded to the SR5 cluster recently. Love having the tach and clock. The only real problem was the speed cable is not exactly at the same place in the two cluster versions. It needs to be pulled way back and rerouted around the dash framework and other wire harnesses so it goes in straight. I also removed those green shades from the background lights, big improvement in night vision of the cluster. I reset the odometer to reflect the original true mileage that was on the old cluster. The plastic frame holding the odometer mileage spindle (which does not turn) can be cracked apart, then 'welded' melted back together with a soldering iron. Speedometer has an internal adjustment tab and the needle can be pulled off, turned and reattached, calibrated it to my GPS speed.
