ECU, Carb & other questions
mcl007
My tercel:: 85' Sprinter Carib AL-25 AV-II
Post by mcl007 »
Hey T4WD!
I'm from Russia and I have a toyota sprinter carib - japans brother of american tercel.
If intresting - welcome to http://www.drive2.ru/r/toyota/960911/ (it's my logbook) for more info
My questions for you:
Do you have a repair manual of tercel/carib al-25 with a Twin Variable Venturi Carburator?
Do you have a ECU pinouts for 3A engine? (any)
My engine version is a 3A-SU
Thanks!
Re: ECU, Carb & other questions
welcome, mcl007. you are one of the few eastern members here. i actually can't think of any other recent or active ones, so you may be the ONLY eastern member right now!
i checked out your logbook but couldn't figure out how to navigate the site. is there a button to translate it to english that i'm not seeing?
i want to see more pics of your engine bay. i can already see that your coolant overflow reservoir is mounted in a different spot than ours, and the emissions stuff looks completely different too. very interesting.
we have a factory service manual for the car available for download here on the site:
viewtopic.php?f=2&t=8103
it has a section on disassembling the carb. also, here is a write-up by a member here on rebuilding a carb:
viewtopic.php?f=7&t=7341&p=54674
and even better yet, here's a video by the same member on how to rebuild a carb:
viewtopic.php?f=7&t=11045&p=81899
i'm not sure by what you mean about 'ECU pinouts'. are you asking what each pin on the ECU is for? if so, i don't believe i've ever seen that info. the factory service manual only ever mentions the ECU in passing, and it never goes over how to check it.
mcl007
Post by mcl007 »
1.
I need a table of names pins on copmuter port. for example:
http://www.kalalahti.com/enginepix/draw ... FE_MAP.gif
but for 3A i can't find anyfing :(
2.
This right hand drive car. Coolant overflow reservoir in this car installed beside a radiator or on right shock absorber cover.
3.
I was download a manual for T4WD in AL21/25, but my carb look like this:
http://3.bp.blogspot.com/-7mEd8bopA1M/T ... 0/carb.jpg
and i have two carb on one intake manifold =)
4. Site drive2.ru - is a russian car fans site, there no English design =(
navigation of my log:
a) Не было забот (there were no worries...) - story about buying this car
b) Капитал 1. За запчастями (Big repair 1. Buying spare part) - story abut buying spare part
c) Капитал 2. В поисках Немо. (Big repair 2. In searching of Nemo) - in my Z52 gearbox does not turn on a 5th gear
d) Капитал 3. Здравствуйте, доктор! (Big repair 3. Hello, Doctor!) - this is diagnostic of my 3A engine
e) Кушать подано! (enjoy your meal!) - i have idea for installing EFI from 4A-ELU engine with 5A ECU in place of carb
if intresting - i can translate for you ))
5. I can take a picture for you to some things, because the engine is not there
P.S.
I do not know the language perfectly, so excuse me if something is written, not as it should
Mark
Post by Mark »
I use Chrome for a web browser and use its translate feature. It worked ok for the Russian Tercel website.
atoyta
My tercel:: 3 wagons now
Post by atoyta »
Try page 876 of the PDF manual, I believe that is what you are looking for.
mcl007
Post by mcl007 »
atoyta wrote:Try page 876 of the PDF manual, I believe that is what you are looking for.
on 876 page i see only colors of wire.
gr-b - grey (or green?) with black
but i need number of pins in ECU where to connect this wire, becouse i want install one k-type carb from 3A-C or EFI if I can not find information of Twin V-carb system. standard wiring is not suited to this option
When I get home I will try to remember to check the wiring manual I have. It is for 85 or 86.
Gottolovem
Post by Gottolovem »
Wow the I have been learning all things tercel
for years now and this is the first time I have heard of a Twin Variable Venturi Carburator :shock:
How cool is that :oldgeek:
mcl007
Post by mcl007 »
Gottolovem wrote:Wow the I have been learning all things tercel
in the world has a lot of interesting things =)
This engine (3A-SU) has a 90H.P. (66kW) at 6000r.p.m.; compression ratio 9.3 vs 9.0 on standart 3A; "swirl intake version" - swirl the mixture on a Cylinder Head channel; two veturi carburator. This engine was made only for Japan.
Hey! I find a English design drive2 =) link: https://www.drive.net/r/toyota/960911/
Gottolovem
dlb wrote: so you may be the ONLY eastern member right now!
Forum member Florrykitty is Ukrainian but lives in Idaho. I think that's as close as we're going to get. :lol:
Welcome to the forum!
I think you can use the wire diagram in combination with the emissions control and fuel system chapters in the manual to determine what each pin does on the ECU. it is a rather simple device, basically a series of on/off relays for certain engine conditions.
Those variable venturi carbs are actually pretty good, they are Japanese SU style carbs (why do you want to put on a two barrel carb if you have twin side draft carbs?. I owned some early volvos, and worked on a number of british cars that had the British version of them. the early Datsun 240z and the Dasun 1600 and 2000 sports car also had them. You will not find much on it in the north american service manual, but I am sure there are website with instructions on how to tune these carbs.
you have to get the throttle plates synchronized so they open exactly the same amount, than balance the fuel mixture in each carb, and than adjust the mixture so it runs optimally. I can do it by ear, but most instructions will tell you to use an exhaust meter (not really necessary but I think most younger people have lost the "ear" it takes to know when it is running correctly). Also, make sure the dampeners have light oil in them to the fill line (ATF works good, do not over fill!), if not they will never run property. Good luck.
mcl007
Post by mcl007 »
This is another car in this configuration from Russia:
https://a-a.d-cd.net/d5a7ce4s-960.jpg
https://e-a.d-cd.net/85a7ce4s-960.jpg
I bought this car it did not work. :( previous owner had prepared her for the repair and sell me. I do not know how to connect the vacuum hoses and wires to where they should be.. so I decided to ask you, because I did not find anything in RU-internet zone...
Can't figure out the scanner yet. Will post it when I can.
