Alright. I'm sick of vapor-lock. Well, I assume its vapor lock as it only happens on really hot days and goes away when the day gets cool.
What is the flow-rate of our fuelpumps? I want to put a pump either in or very near the fuel tank to supplement the one on the block. This, if it proves inexpensive enough, may actually be financed by my parents. Anyone know? If not, can anyone recommend a good number?
Fuel Pump
Lowest I could find was a Holley 97 GPH at Autozone. NAPA's site is down. Might check Advance next.
Advance has this listed under the 86 SR5 Terc. Univ application, but it must be similar flow if it's under the model. *Carter P60504*
