Fuel Pump Check
Re: Fuel Pump Check
The car may not be timed right as it is, for it not being able to start. A timing light, bought or rented, would be a good investment too, as you'll want to be able to check the timing anyway.
Re: Fuel Pump Check
ignition timing is no big deal, you just need basic tools and a timing light. i think you can even borrow timing lights from some parts stores. here are instructions on how to remove and install the dizzy.
https://tercel4wd.com/forums/viewtopic.php?f=4&t=7664#p56030
- brentskibikeski
- My tercel:: 85 Toyota Tercel Wagon 4WD
Re: Fuel Pump Check
Swapped out the distributer and it worked like a charm. Plus, since I replaced the spark plugs and wires in the process it's never run better.
Re: Fuel Pump Check
great to hear it. thanks for posting the resolution, it's really useful to future forum users.
