having a real problem getting the parts here..i got the parts #'s from the forum for parts numbers and can cross referance from 04421-12011-77 to 88506BR at autozone here in baja california sur..its the only parts store around here..the seal is problem..2 weeks to wait..any ideas to speed this up?
OE part numbers, as obtained from Butler Toy September 2010.
The first price is regular OE retail - the second is Butler's. Note that all are quite competitive withAM parts and better than other Toy dealers.
04421-12011-77..Bearing kit...................57.73.....2 @ 43.30.....86.60
42454-20010......Bearing retainer LH.........8.46.....1 @..6.35.......6.35
42424-20010......Bearing retainer RH.........8.46.....1 @..6.35.......6.35
42185-52030......Gasket axle housing end...7.89......2 @..5.92.....11.84
42425-52030......Gasket to retainer..........2.43......2 @..1.82......3.64
94181-11000......Locking shoulder nuts......1.66......8 @..1.25.....10.00
90311-42055......Oil seal.......................5.56......2 @..4.17.......8.34
axle bearing a seal from autozone in mexico
Re: axle bearing a seal from autozone in mexico
you can drive to San Diego and have the parts in one day from most Autozone, or NAPA store. not sure if that is practical where you are at. Although at large inconvenience to you, likely with the drive up and back it should not take you more than 2-3 days to get everything you need.
If you do this, I would call ahead and ask them to preorder the parts so they will be there when you arrive, I have done that once, I was driving to Austin TX from California and realized I was going to need a radiator soon, so I ordered one when I was on the road from O'Reiling (they had one in stock, I called all of chain stores in Austin), and they had it ready for me at the local store where I was staying the day I arrived. No extra charge.
- My tercel:: 1984 4X4 toyota tercel SW automatic
diesel at over 4$ a gallon that wud be an expensive repair...im in cabo.i got the bearing here in 2 days..the seal may have to wait till next year or my buddy comin down may pick 1 up..ill just drive it little trips no off roading till i get the seal
did you look on rockauto or other online parts sources?
