14 x 7.5?
hikersteve
My tercel:: 84 sr5 manual
14 x 7.5?
Post by hikersteve »
Is there any way to make a 14" x 7.5" rim work on 84 tercel wagon?
hikersteve
Re: 14 x 7.5?
They have positive/shallow offset and the depth from inside back of rim (behind lug holes) is approximately 5.25"
Re: 14 x 7.5?
you could make it work with longer wheel studs and spacers (if I understand which direction the off-set is correctly). the problem with this is buying longer wheel studs is not cheap (like $60), plus spacers, but worst of all it will put a very large bending moment on the suspension and wheel bearings having the wheel so far off-set.
hikersteve
Re: 14 x 7.5?
The offset is towards the road side, so the wheels wouldn't be "skating"/sticking out from wheelwell.
Could this be feasable for summer drivin/ non 4wd?
