Weber
Weber
Looking for a good used Weber for Pokey, as Dad doesn't want to deal with vacuum lines. I'm not even sure it'll work that well there in the winter, but hey if it worked for David it should work in Colorado!
Bonus points if it is a bolt on job and ready to go (modified bellcrank?)
I'm looking for the 32/36 DEGV right? Is there a source for the conversion kit and or a new weber? I'm looking on Ebay and I see the weber, but no conversion kits for our cars.
Edit: kit number is K-740
Okay, so there is a new one if I can't find a used one.
http://www.ebay.com/itm/Weber-Carb-Kit- ... 6f&vxp=mtr
BrownBadger
My tercel:: 83 4WD Tercel SR5 - The Brown Badger
Re: Weber
Post by BrownBadger »
I have a good used one with the adapter kit which came off of another member's Tercel. Id take what I paid for it - $125 plus shipping.
Re: Weber
So it is ready to go? Shipping would be to 81425
BrownBadger
Re: Weber
Just needs a gasket set I believe. Ill pull it out of its box tonight and look at everything for you and snap some photos.
BrownBadger
Re: Weber
Here are the photos. This was ex-forum member GotToyota?'s carb which he had installed and said worked great before he upgraded his engine and then disappeared from the forum.
The Professor
Re: Weber
Post by The Professor »
Did you ever sell the Weber? Does it have the modified bellcrank?
BrownBadger
Re: Weber
Still have the weber. It does have the tercel bellcrank on it.
