1982 Cressida any good?
Depends on if you want another project I guess. Cressida's are nice cars. If you can get your hands on a cheap replacement motor (and are comfortable swapping), I'd say go for it. I loved my Cressida (I had an 85 for a while).Carguylen wrote: I have a chance to get one real cheap. The owner says it overheated and they have not driven it since. Says it needs a new freeze plug (?) and that they were told this is difficult to get to and replace. Any thoughts or anyone interested if it runs?
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
I found out it's a 1988. Is that any better? Or worse? I figure if I can get the freeze plug thing fixed, I can always sell it. It overheated and then they shut it off immeditaly, had it towed home. I've had cars overheat, but if the freeze plug is bad, is that real bad? I know it's hard to tell without seeing it, but.....
The 88s are my personal favorite. The engine that is in there (the 5mge) is nearly invincible. I don't see why the freeze plug would be a big deal to replace. The same thing happened to my parent's in law's 88 Cressida. I've never replaced one myself though. If they shut the car off as soon as it got hot, the engine is probably fine. Replace the freeze plug, fill with coolant, and away you go.Carguylen wrote: I found out it's a 1988. Is that any better? Or worse? I figure if I can get the freeze plug thing fixed, I can always sell it. It overheated and then they shut it off immeditaly, had it towed home. I've had cars overheat, but if the freeze plug is bad, is that real bad? I know it's hard to tell without seeing it, but.....
In case you did not know, Cressidas are basically Lexus before Lexus. Also, they are built on the Supra platforms. So the 88 Cressida is built on the Mark 2 Supra platform. Same engine, same auto trans, same rear end (IRS with LSD) etc. Very very nice cars.
If the rest of that car is in good shape, I'd totally pick it up if I were you.
Check out this forum for more info: <a href='http://www.thermactor.com/forum/' target='_blank'>Cressi Forum</a>
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
42mm freeze plug (should be anyway) and it must be metric if it is. The equivalent in imperial will pop out on you.
They cost about $0.15 or so and can be easily popped in with a rubber mallet!
7mgte swaps are very common and can produce good power!
Have fun and good luck
'84 Tercel HB, 202hp Turbocharged 20v, 4WD, Lowered, Custom exhaust, Mangles Rims with Avid V4 Rubber! Hola!!
Haha! There ya go!20vtercel wrote: They cost about $0.15 or so and can be easily popped in with a rubber mallet!
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Wow. When you look at a car, look at it all the way around. It looked real nice on the drivers side, but the passenger side is trashed. I was doing some electrical work at the house and I saw the spider webs under the car so I asked if they wanted it, they said no, and I didn't look all the way around it. By the way, do the 88's have separate low and high beam headlights? i thought they were composite.
They are composite. I think they use 9004 bulbs.Carguylen wrote: Wow. When you look at a car, look at it all the way around. It looked real nice on the drivers side, but the passenger side is trashed. I was doing some electrical work at the house and I saw the spider webs under the car so I asked if they wanted it, they said no, and I didn't look all the way around it. By the way, do the 88's have separate low and high beam headlights? i thought they were composite.
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
