Funny shifting
Carguylen
Post by Carguylen »
My car is an automatic, and it shifts from third to second quite often when I'm going uphill. Back and forth third to second. Also, when i'm on the freeway, I let off the gas and after a few seconds it feels like a stick shift car when the clutch is in and then you let it out real quick, just for a split second. Strange....
GTSSportCoupe
Post by GTSSportCoupe »
Carguylen wrote: My car is an automatic, and it shifts from third to second quite often when I'm going uphill. Back and forth third to second. Also, when i'm on the freeway, I let off the gas and after a few seconds it feels like a stick shift car when the clutch is in and then you let it out real quick, just for a split second. Strange....
You may not like my recommendation...but here goes: swap it out for a manual 6 spd tranmission. ;)
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Carguylen
Post by Carguylen »
How about a 5 speed. I can find one of those easier?
clbolt
Post by clbolt »
Carguylen wrote: How about a 5 speed. I can find one of those easier?
Not in a 4WD Tercel.
Gasoline Fumes
Post by Gasoline Fumes »
It's been a while since I looked at an auto Tercel. Is there a mechanical kickdown linkage? I'd try adjusting that. It might reduce the "gear hunting" on hills. Or just manually shift into 2nd.
I'd do the manual swap. :)
brianp
Post by brianp »
Hey guys, when you say a "6-speed" you mean it has EL, 1, 2, 3, 4, 5 and reverse, right? And then a "5-speed" would mean it doesn't have the EL?
GTSSportCoupe
brianp wrote: Hey guys, when you say a "6-speed" you mean it has EL, 1, 2, 3, 4, 5 and reverse, right? And then a "5-speed" would mean it doesn't have the EL?
Correct. The 5spd only came in the fwd wagons.
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
