WTB: need some small things for my tercel
I am looking for the small piece of trim that goes on the fender on the passenger side, the rear passenger side mudflap, and a set of brown shift boots(small and regular. I would also like to purchase a roof rack. I do not know how expensive these parts will be so not sure how soon I will purchase. Thanks
Re: WTB: need some small things for my tercel
I can't help with the parts, but for the shifter boots, see https://tercel4wd.com/forums/viewtopic.php?f=7&t=5074
If I can make these, so can you!
for roof racks, you can find old gutter-mounted roof racks on craigslist for free or very cheap. new cars don't have gutters anymore so lots of people are getting rid of their old roof racks.
alternatively, al25's came with a couple different roof racks, probably installed at the dealerships. both are detailed in this thread. they are more work to install as you have to drill into the roof to install riv-nuts so you can fasten the rack down. be careful if your terc has an electric sunroof, i almost ran into some issues with that when i installed a one of these on my green tercel.
https://tercel4wd.com/forums/viewtopic.php?f=2&t=7697
Mine does not have a sunroof. I love the rack on your green Tercel. I haven't seen one like that. I had only seen the other rack
Do you still need the roof rack? I removed mine a few years ago but will see if I can find it if you still can use it.
'85 4wd daiily driver
'85 4wd for parts
'85 4wd for parts
