Windshield Wipers
jpkeels
Post by jpkeels »
I have a repair question. ON my 85 2wd wagon the wipers work but they don't move as fasr as they should when they are running. In fact, when I use them I have to peek to the right a little to see out because the driver side wiper doesn't go all the way across the windshield as far as it should. I have played with them briefly and noticed that there is several inches of slack in the wiper mechanism. The wiper motor itself works fine but I am wondering how hard of a problem this is to fix. I am thinking if there is a way to get into that area to replace the linkage that maybe it is something fairly easy to fix. Perhaps even get a replacement part from the junkyard. :)
What do you all think? :)
GTSSportCoupe
Post by GTSSportCoupe »
jpkeels wrote: I have a repair question. ON my 85 2wd wagon the wipers work but they don't move as fasr as they should when they are running. In fact, when I use them I have to peek to the right a little to see out because the driver side wiper doesn't go all the way across the windshield as far as it should. I have played with them briefly and noticed that there is several inches of slack in the wiper mechanism. The wiper motor itself works fine but I am wondering how hard of a problem this is to fix. I am thinking if there is a way to get into that area to replace the linkage that maybe it is something fairly easy to fix. Perhaps even get a replacement part from the junkyard. :)
You've probably already tried this, but have you unbolted the arm and tried turning it to a different angle, then rebolting to see if it made a difference? Is your wiper hitting the bottom seal of your windshield?
If it's not the adjustment, maybe the mechanical mechanism is worn out (probably the case from what you are saying?) I've never replaced the mechanism before, although I've replaced the motors before.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
jpkeels
Post by jpkeels »
It has some slack in it. Sometimes the wipers hit the seal at the bottom of the windshield and other times they do not. Also, if you turn the wipers on high, the momentum from the movement actually causes the driver side wiper to slap too far and actually hit the seal on the Left side of the windshield which is actually the opposite of what it does when you leave the wipers running on low and have to peek to the right of the problem. It is kind of funny when it happens actually. How hard is it to get into the area where the mechanism is. I mean its behind the firewall and doesn't look easy to get at? :) I will still try loosing the bolt on the wiper and try some adjustment as well but I still wonder. LOL
Crazy stuff. Of course the driver side mirror is also loose but thats a seperaate topic. LOL I plan on getting one from a junkyard and fixing the mirro when I can. For now, the mirror is epoxied into place inside the mirror frame. LOL The mirror fram itself is also a little loose. LOL
Post by Chris »
It sounds like you have some worn linkage bushings. To access them you have to remove the cowl between the windshield base and the hood.
jpkeels
Post by jpkeels »
Thanks for the suggestions on the wipers. I will have to get underneat that cowl at some point. Over the weekend I did loosen the bolt and adjust the wipers a little bit so taht they will cover more surface on the windshield. It has not rained here for a few days and probably won't for a couple more days so I will have to be patient to see if my adjustments help. :)
Eatpants
Post by Eatpants »
my cowl is carpeted with pine needles and the paint on the roof all ruined thanks to 2 years under the pine tree
jpkeels
Post by jpkeels »
Well, I adjusted the wipers a few weeks ago and have used them in several rainstorms lately. Unfortunately, the wipers still do not quite cover the whole area they should. They work just not real well. At some point I will have to tear off the cowl. This will be another interesting project to work on. I'll have to find the bushing replacements though. :)
Could be that they are loose where they mount...there are some tapered serrations there...one side is soft...the other hardened metal....need to clean out the soft stuff from the hard serrated side and snug them down good. The special nut they use can strip also.
New arms might help.
GTSSportCoupe
takza wrote: Could be that they are loose where they mount...there are some tapered serrations there...one side is soft...the other hardened metal....need to clean out the soft stuff from the hard serrated side and snug them down good. The special nut they use can strip also.
Takza! You're back! :)
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Might be...then again I'm not too sure..... :blink:
Snax
Post by Snax »
Reviving an old thread here . .
So can anybody confirm what should fix this problem?
I've rotated my driver side arm one spline to address the visibility issue, but now it doesn't go all the way to the bottom seal like the passenger side, and it runs off the windshield on high or into a high headwind.
83 SR5, 32/36 Weber DGEV
94 Escort LX Wagon
11 Flex SEL
Well - when I was a kid, this happened on a Morris I had. I resolved it by positioning the arm on the stud and drilling a small hole through it all and then used a thin bolt and nut to secure it all.
Something more elegant would be to drill the hole and tap it for just a bolt.
Snax wrote:Reviving an old thread here . .
You have to "park" them...shut them off. Reposition the offending arm...might need to clean the splines.
You probably don't want them to park in a way that forces them down on the moulding...cause this will warp the rubber squeegee.
I HATE replacing wiper glades...PITA.
Meck
Post by Meck »
The plastic/nylon bushings are gone. Get to them by going through the hole behind the wiper motor. It's a mess to do. I made replacements by cutting down/filing/etc. some brass bushings. No problems since, and the wipers move pretty much the distance they're supposed to. Good luck.
'85 4wd daiily driver
'85 4wd for parts
Snax
Post by Snax »
I don't like the looks of that. I don't have smallish hands, so if I have to reach in behind the motor, I'm probably screwed.
Thanks for the clarification.
94 Escort LX Wagon
11 Flex SEL
