My car is getting hot. I just got it last week, and it's been sitting for a year or so, so I put some Prestone Super Flush in it, the fan is going on when it's supposed to, so I wanted to take the thermostat out. I know some cars don't run as good without them. I live in southren California, so it isn't going to be cold for a while.
Is there a problem running the car without a thermostat?
Thanks..
overheating...
No problem at all.
Just so long as you remember to put one back in before it gets cold.
Else it'll take absolutely ages to warm up when you first start it.
I had mine without a thermostat for a winter, as it failed in summer and I didn't have the cash to replace it.
1983 Tercel SR5 with 185/75R14 tyres, 32/36 DGAV Weber carburetor, lumpy cam and upgraded Pioneer sound system. Veteran of several fire seasons (with the scars to show it) and known as "The Racing Turtle"
Ditto that - my Bentley warns of the same thing.
Have you looked at your radiator's condition? The '84 I purchased was missing about 1/3 of its fins, right in the area where the fan blows through... The joys of purchasing a car that spent its life on the coast...
Good luck,
Jerry
Good luck,
Jerry
Jerry
Bakersfield, CA
Owner of a rusty '84 Terc SR5 4WD
251,000+ miles, original engine, second transmission.
Transmission soon to GRENADE!
Bakersfield, CA
Check for a significant number of flattened fins. Air doesn't flow through= fluid doesn't cool.
Is there an aluminum rad. that will fit?
Fan is supposed to go on until your engine is cool.Carguylen wrote: I ran some Super Flush through it, put a new thermostat in, and put new coolant in. See what happens. I was wondering if the fan is only supposed to go on for 15-30 seconds max. Mine is doing this. I might need a new switch.
Thanks for the info
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
