Cheapest way to get a 2" lift? Anyone
lilcurt503
My tercel:: 1986 tercel SR5
Post by lilcurt503 »
Hey guys new to this what's the cheapest way to get a 2 in lift on my tercel sr5. And my friend and I were thinking of putting razor tires on. Is it safe? Thanks
Re: Cheapest way to get a 2" lift? Anyone
welcome to the forum,
two easy way to lift the rear: get air shocks for an adustable ride, or Nissan Pathfinder rear springs with firbird (longer) rear shocks.
front eaisest way is to shim down the top of the strut mount. I would not recommend 2" in front, you will damage your cv axles at that angle and damage the upper seal on the strut (so it will cost you a lot in repairs). keep it at about 1" or 1.5" max, and than get a taller wheel and tire, but you might have to clearance out the fender and fender well.
Go read the FAQ section, there are links to threads on this topic.
