New member from Portland, OR - '86 Tercel Wagon DLX
Re: New member from Portland, OR - '86 Tercel Wagon DLX
did you also swap out the oil pick-up that goes with that pan? the oil pick ups are different for each pan, the oil pickup for that 3ac Tercel pan has to go that oil pan.
- My tercel:: 1986 Tercel Wagon DLX
Yes sir, that was all done.
Will update more this week, hoping to be done by Thursday. Head has been torqued down, motor mostly assembled.
Carb or FI?
Take a look, what do you think? (wink)
That is beyond my knowhow!
- Gottolovem
That's fuel injection Petros commented on what kind earlier in this thread
We have a winner!Gottolovem wrote:That's fuel injection Petros commented on what kind earlier in this thread
- Gottolovem
have you worked out the exhaust yet
That will be the interesting part. It has to be all custom.
I've ordered an aftermarket header but apparently it might not clear the steering linkage. I'll know for sure tomorrow.
- Gottolovem
That engine on a 4wd transaxle is pushing the limits of what it can handle manageable though If you don't romp on it to hard!
Good thing you are 2wd
That's what I was thinking. I have an upgraded clutch so that it can handle the new motor setup.
So you got the wiring harness all in too?
Wiring is going in tomorrow. Flywheel is being machined then it's all going back in to get the last few things patched up. Fuel pump installed, misc. wiring, etc.
Once it's all done I will write up the parts I used.
Flywheel resurfaced!
