Terc delight
KZ750
My tercel:: 1985 tercel sr5 4wd
Re: Terc delight
Post by KZ750 »
I got this design from the tow hitch on my unit body cherokee.
The 2x6 box tubing is going to be welded into the brackets, then the origonal bumper will have a section cut out of it for the tube to sink into.
I'm thinking sleeper winch bumper, but not as sleeper as what they have factory in other countries. what do you guys think?
KZ750
Re: Terc delight
Post by KZ750 »
I think I just thought of something even better then my first ideas, but I have to go to work and leave for LA. Crap. Anyways, I'm thinking of making a bracket that connects to the recover tabs (three bolts) and then back into the inner fender well area, where it will bolt into the unit body frame rails through the sides. more simplistic. I will have to move some power steering lines out of the way, and the body rails kind of tapper out towards the front, so the bumper might have to be installed from the ground up instead of being pushed on.
KZ750
Re: Terc delight
Post by KZ750 »
Hey thanks gottolovem. It does have spark to cylinder one, but I think it could still be the problem. it sounds like it is sometimes firing else where in that plug wire before the spark plug...sometimes.
Gottolovem
Re: Terc delight
Post by Gottolovem »
call me if you still have my number
Re: Terc delight
KZ750 wrote:Sad to say, cylinder one is not firing, even at different RPMs. so i'll be looking into that. even before the new motor, the car didn't fire on cylinder one. has spark, not sure about fuel? is this somehow TVSV related?
not likely related to the TVSV. it only directs vacuum to different places based on temperature.
did the new engine not come with its own distributor? i would look at the cap, rotor, and wires first. someone else here recently had a problem they couldn't solve, turned out to just be a worn cap.
KZ750
Re: Terc delight
Post by KZ750 »
dlb- nope, the engine came as is. no oil pan, distributor, nothing, just block, head, valve cover. The rotor and cap looked okay when I opened it up to find the position of the rotor for timing. Is it possible that I could test the distro/ plug wires by connecting the cylinder four position wire on the distro to cylinder one?
Gottolovem- I'll be sure to give you a ring once I'm back in town.
Here's what I cam up with.
Blue lines represent the plastic bumper, and the red lines show the bumper bracket. the solid red boxes represent the the box tubing. I did not sketch in the original bumper, because it would complicate the image, but it will be utilized.
Gottolovem
Re: Terc delight
Looks like you definitely have some skills when it comes to fab work.
In my opinion the best way to check the ignition system Is to swap it out.Pretty much the entire thing is inside of the distributor.
There is a half off sale this weekend at pick&pull do you want me to get you a dissy if they have one. It's one of those parts that should carry an extra one of.
Re: Terc delight
If you have one plug that isn't firing, it has to be that wire, plug or terminal on the cap specific to that cylinder. If the other three are firing, the distributor should be ok.
Re: Terc delight
you might consider on your bumper a single bar that rises off the top at one end, loops across the front at radiator cap height, and than turns down and welds to the other side. It will protect the head lights, side marker lights, and keep deer off the radiator and hood when they wander on to the road.
hitting a deer is hard on the radiator and body work.
KZ750
Re: Terc delight
Post by KZ750 »
My hotel has Wifi! whoop whoop!
Gottolovem- Pick and pulls half off and I'm out of town?!?!?!?! ahhh dang! Don't worry about chasing a distro for me. You're too nice man! Did you see that they're down to two tercs in the yard?
Good idea petros! Maybe I can find away to make the hoop a bolt on part of the bumper so I can still use the plastic bumper skin.
Check out what I found today!!!! In the small lake town of Mono, 395 south from Reno. I had to pull over to take pictures.
Maybe it's one of us?? I wiped the plates and street signs to be respectful.
Gottolovem
Re: Terc delight
Haha I can't count the times I've driven through there. Spent a couple weeks in Lee Vining Rv park with my daughter a few years ago. We bounced around Yosemite, Bodie, Mono lake and mammoth. Good times.
Only 2 tercels at pick&pull if there the same two that have been there for a while now I bet there bare bones.
Is it the one tan 84 that had your inclinometer And the 88 at the end of the same row?
I wonder if there is any in Carson City?
KZ750
Re: Terc delight
Post by KZ750 »
I can't wait to get my Tercel road trip worthy! I'd love to go down to Yosemite.....or even Yellowstone. The car just fits that little town Mono so well, it's almost beautiful.
Oooh, Carson's got an 85 in the yard. And yeah, just the two tercels that you mentioned are left.
Gottolovem
Re: Terc delight
Have you seen the one in Carson or just searched it.
I should grab the tranny if any good.
Gottolovem
Re: Terc delight
How did you end up in mono it's a little off of 395 didn't you say you were heading to LA.
tercel4wdrules
My tercel:: None
Re: Terc delight
Post by tercel4wdrules »
I had a problem in which one of the cylinders wasn't firing properly. It turned out my intake manifold was cracked, and so was cylinder head on that same runner.
2015 Honda Fit EX "Malachi"
