Hi Guys,
I have this car back up for sale in case anyone is interested. I had removed the ad when I realized there was a compression issue with the engine that was in it - (The PO had put a junkyard engine in it when the original timing belt broke years ago).
- I got the original engine with the car, and now have the original engine back in the car with new head gasket, timing belt, plugs, fluids, etc.. 180 lbs of compression right across. Not sure how many Km's were on it when it was pulled but it was super clean inside. Also within the past few weeks I replaced the rear brakes, serviced the front brakes (decent shape), put a proper stereo in it, and cleaned up a few other things. The car drives really nice now, and seems to be pretty much as it should be. I ended up putting a spare carburetor on it, and it starts up easy and idles nicely - for some reason the brand new "FC" carb I had didn't work properly - seemed to be running extremely rich. If anyone is interested in the car or has any questions please let me know, I can send photos, etc..
Thanks;
Len
http://vancouver.en.craigslist.ca/rds/c ... 17239.html
'87 4WD 6MT in Vancouver - $3200
Re: '87 4WD 6MT in Vancouver - $3200
Looks sweet! Love that tri-color combination.
You might add info about exhaust system - the pipes, at least, look pretty new.
Good Luck!
Good Luck!
