Why are all the 1st gens way too far away from me!
If anyone around the Arlington area who will be going by the pick and pull anyway has time, I'd like a few parts of this tercel, this is almost all little easy things.
In order of importance
Engine parts:
Heater control valve if it functions (the one on the firewall) plus hoses if good
charcoal canister plus vacuum lines and vent line to carb if possible
MCV with both hoses
The VCV, vacuum switch, BVSV, TVSV, gas filter
check valves, jets, vacuum transmitting valves (VTV)
(you can keep the TVSV if it works, should be the all metal one)
Inside parts:
plastic trim that covers the front seat belts
both front seat belts if in good shape
Glove box if completely intact with the little piece that prevents it from opening more than 90 degrees, or that piece if it can be removed
If tan, steering wheel cover
AC switch
defroster switch
multifunction switch (headlight, turn signal, wipers) if everything works well and the writing is intact
inside door handles
sun visors if in pristine condition
if Manual, the shifter knob if readable
If the front seats were mint and I could confirm they fit mine (will get measurements) I would probably try and see if it were possible ship those! Or perhaps just the seat foam!
Will pay for your time, shipping, and of course, whatever the parts+tax cost! Can do paypal, or send a check or money order.
