cuts out and dies at temp
- Gottolovem
Today I gave a short tow to a woman out of gas just a hundred feet or so. After I left her at the gas station I noticed that my idle started to surge up and down. Ten miles down the road the car started to cut out all together and die. After calling a friend to tow me back home I found a couple of bad plug wires so I swaped them out and car ran fine until it came up to temperature then same symptoms. Towed it home again and swapped the carb for a known good one and car ran good again until I get up to temp then she cuts out all over again. I am stumped any advice would be gerat. It is so frustrating it seems to run great until I'm heading down the road with a load on the motor. Again this started after I put a big load on motor towing another car.
- My tercel:: T4WD#4: '86 SR5 6-speed, original Barto lift & steel bumpers & winch, also 95Amp alternator
Re: cuts out and dies at temp
If you have a spare distributor, I would swap it out. If we pick ignition as the problem over fuel, there are three electronic things inside the dizzy: The pickup, the igniter (ignition module), and the coil. The distributor pickup is my guess for a temp related problem, based on experience with other vehicles (not Tercels). In my experience, the igniter seems to just die and that's it, and the coil, well, I've never had one die on me yet.
You should be able to test it with an ohm-meter. I've got a working used pickup that reads 158 ohms, both connected to the igniter and disconnected.
(pickup at top, igniter at bottom - you must remove a plastic cover to expose those screws, and they are super tight - also you need a torx bit to disassemble and it is a pain in the ass to work with that aluminum coil mounting post sticking right in your way)
- Gottolovem
I do have another dizzy I will give it a try tommrow it does have one less vac line on it though. I hate to mess with vac stuff on these t4s. Thanks for the suggestion
you can easily swap the vac advance units on your dizzy's. just remove the one screw that holds it in place and pop the arm off the peg that it hooks on to.Gottolovem wrote:I do have another dizzy I will give it a try tommrow it does have one less vac line on it though. I hate to mess with vac stuff on these t4s.
- Gottolovem
photo of snow plow for the member that wanted to see it
Now that is awesome. What method is used for adjusting height? And it detaches and leaves that small rectangular frame in the center of the bumper?
I've got an ATV plow sitting right next to my Terc right now, except it's not mine. I may just have to repossess it.
- Gottolovem
The plow doesn't really have a way to adjust the height there is a chain to hold it up when not in use or it sits on the ground with little skid plates to prevent the blade from digging in to the ground. It does detach from the bumper i will try to post more pics on how it was mounted soon but the car is on loan until i can figure out to fix the car i started this thread about.
- Gottolovem
Still no luck changed out the dizzy and still cuts out when under load. Pulled fuel line off and turned over plenty of fuel.
is it still only happening when hot? how do your spark plugs look?
i also wonder if one of the fuel cut off solenoids could be faulty.
Does it fail hot or cold? Have you checked the accelerator pump in the carb?
- Gottolovem
So far i have changed out dizzy,plug wires, entire carb, alternator, and relays with known good ones off another running car. The plugs are just about all that's left on the electrical side and i will do those when i get home.
Sorry, I missed the fact that you already tried another carb. It's probably a bad spark plug.
- Gottolovem
you said you checked the fuel output but didn't mention when. i would check it both when cold AND hot to verify it is a fuel issue. the only heat-based fuel problem i can think of is vapor lock but with your current temps in reno i can't imagine that being it.
This is prob farfetched, but you never know...
How about the rubber fuel lines getting overheated and closing up? It would certainly be cheap enough to renew them. For that matter, are the vac hoses OE still?
Poss some of the hoses are crumbling on the inside.
