Anyway, she's burning about a quart of oil every 200 miles. Funny thing is we can't see any oil smoke! We tested compression before leaving and the numbers were good, but it looked like#4 cylinder had oil in it. Seems to lose oil much faster at higher RPM's (lost more oil than usual after 100 miles of 75-80 MPH and 4200-4500 rpm)
On the way home I tried a range of solutions, no smoke, Restore, STP additive, nothing helped, it just burned those as fast as it burned oil. Did not try seafoam in the oil yet, may try a full flush before attempting this job.
Petros showed us how to replace a stem seal, so I think we can tackle this job. I'd like to know what exactly we need to have so I only have to have the valve cover off once!
1-2 sets of valve stem seals
Valve cover gasket/seal
Any other gaskets or seals required?
Will rent a spring compressor at autozone. This looks cool but don't think I'd ever replace enough seals for it to be worth it.
