I dont know if this is the right place to post this but here goes
1- I need a left front corner light lens
2- also a cover for the inside left rear tail light
any help would be good
Thanks Shchuck
1985 4WD WAGON
1985 4WD WAGON
Shchuck
85 4x4 Tercel Wagon
85 4x4 Tercel Wagon
Re: 1985 4WD WAGON
welcome, shchuck. where are you located?
Re: 1985 4WD WAGON
lots of members in WA and OR so i'm sure someone will be able to help.
for the left front marker light, i think you will need to replace the entire headlight trim piece. i'm not positive but as i recall, the lens is permanently set in this piece. not a big deal, you just pop out the grill (one screw and 5 fiddly plastic clips), undo four 10 mm nuts and unplug the two marker lights, and the trim piece comes out.
