Will miata wheels fit?
- My tercel:: 83 toyota tercel 4wd wagon
Does anybody know if stock miata rims would fit on a 4wd tercel?
1983 brown tercel 4wd wagon daily "Turk" in the process of lifting
1983 white tercel 4wd wagon "J.D." trying to get it running
Re: Will miata wheels fit?
yup, they will. anything with a 4 x 100 mm stud pattern will fit. here's a good list of other wheels that fit.
https://tercel4wd.com/forums/viewtopic.php?f=3&t=8122
I installed "Gen I" Miata 14" Daisy wheels on Goldie a couple of years ago. There is also a Gen II Daisy-ish wheel that looks even better.
What size tire do you reccommend?
i liked 185/65r14 on my 14" wheels.
I went with 185/60R14 Kumho Solus KR21 (All Season type) tires, mostly to keep the speedo error to nil. The handling IS improved because of the wheels, athough the understeer is still present.
What would you recommend as a good offroad/snow tire?
