engine running hot and dieseling
applewew
My tercel:: 1985
Post by applewew »
Hello,
Today, on my way to work, I noticed the car was running hot (in the middle of the way), also, it has started to diesel more often.
Background:
- The car runs with no thermostat, and the radiator fan stars as soon as the key is on ignition. Because of this, the car hardly gets any hot (not good, I know). So this is why I'm concerned.
- The car has a broken TVSV and several other vacuum hoses are plugged/disconnected (see: viewtopic.php?f=4&t=8069&p=58723#p58723 for pictures)
- Oil and spark plugs recently changed
Re: engine running hot and dieseling
how is the radiator (clogged)?
are you losing water or seeing white smoke out the exhaust once in a while (headgasket)
how is the radiator cap (rubber gasket)?
any water leaking out of waterpump?
celtglen
My tercel:: 84/2WD/Wagon-stock/311+K miles-original engine/original owner/ no mods
Post by celtglen »
Deleted duplicated post
celtglen
Post by celtglen »
Hello,
This is not hot it is normal, also, it has started to diesel more often.Running hot and dieseling more often--IMHO..indicates timing..check and reset your timing
Background:
- The car runs with no thermostat, and the radiator fan stars as soon as the key is on ignitionThis usually indicates that the thrermostat switch (temperture switch) is unhooked-or burnt out-or the two wire connectors in side the plug in to the switch are bad..you may just have to strip them and reattach. The fan running the moment the key is on is sort of a fail-safe..I think. The switch is on the lower right corner of the radiator near the bottom water inlet hose..bottom radiator hose.. (PO had no mechanical skills at all, and Nicaraguan mechanics usually do this kind of stuff because they don't know any better). Because of this, the car hardly gets any hot (not good, I know). So this is why I'm concerned.
- The car has a broken TVSV and several other vacuum hoses are plugged/disconnected (see: viewtopic.php?f=4&t=8069&p=58723#p58723 for pictures) OMG! Well the good news is it looks as though you would be able to remove the base nut which HELD the TVSV and they are easy to find and replace. The bad news is, IMHO, not much is working on this car esp. w/o the TVSV because it runs so much of the vacuum settings.
Have you downloaded the FSM yet? PLEASE do so, it is filled with how to test and what to test next information.
applewew
My tercel:: 1985
Post by applewew »
xirdneh wrote:how is the radiator (clogged)?
I really don't know, I guess I have to check. But I guess it is ok.
Not that I have noticed (head gasket), and I'm very paranoid about this after my truck had this problem.
No rubber at all, just the metal =/
Not that I can notice
celtglen wrote:
Hello,
I will do this on the weekend, I don't have the required equipment, so I guess I'll have someone else do it
Background:
The switch is indeed burned, and therefore, disconnected, I've tried to looking for the part here, but no success. I do hate the fact that it never reaches good operation temperature, I hope to buy the switch and the thermostat online.
I'm currently waiting for a TVSV and Carburetor rebuild kit to arrive from the U.S., that will take at least two weeks, I'm hoping to reconnect all those lines when they arrive. But I'm a bit affraid that I will find something else broken/not working when I do that, and then I would have to wait for parts again.
you can test a rad by doing a pressure test on it. requires a specific tool but it's better than replacing parts based on guesses.
that obv needs to be replaced ASAP.
timing lights are fairly cheap and i use them frequently on my cars. another good tool to have.
this is the reality of fixing up a neglected car. it sucks but it's better to find and fix all the problems now so they don't get worse and cause greater damage in the future. my first car was an '87 dodge omni. it was a great car but i wrecked the engine because the rad had a leak. at 17, i didn't realize what a big deal a leaky rad was and wound up overheating the engine and warping the cylinder head. i didn't know enough about it at the time and my dad had no interest in fixing up a "beater" (although it was actually in very nice shape) so that was the end of that car. moral of the story: deal with problems sooner than later.
applewew
My tercel:: 1985
Post by applewew »
dlb wrote:this is the reality of fixing up a neglected car. it sucks but it's better to find and fix all the problems now so they don't get worse and cause greater damage in the future. my first car was an '87 dodge omni. it was a great car but i wrecked the engine because the rad had a leak. at 17, i didn't realize what a big deal a leaky rad was and wound up overheating the engine and warping the cylinder head. i didn't know enough about it at the time and my dad had no interest in fixing up a "beater" (although it was actually in very nice shape) so that was the end of that car. moral of the story: deal with problems sooner than later.
Yeah, I really want to get the car to the best shape possible. I even considered buying a master rebuild kit, so I can make sure everything is tip top. What concerns me, is that it temporarily ends in a state that I can't use it until new parts arrive, since this is my daily driver.
celtglen
Post by celtglen »
Just be prepared that this MIGHT happen..though the good news is that these little buggars are as tough as nails! I swear the car has a soul..over the decades I have talked to "her" and asked her to PLEASE keep on running until I could fix her properly. The CV AND rack and pinion bellows on both sides split one year. I wrapped duct tape around them--fancying bellows as I did--and drove her carefully for TWO YEARS until I could get them replaced.
I am certain ALL OF US have stories of our tough Toyotas coming through for us!
I am an old Scout..BE PREPARED! :D
I'd get that rad cap replaced, I just replaced mine (this week) and this time opted for the lesser expensive one..that is w/o the "safety" lever on the top..7 bucks..its a china made one that is to OE specs..kinda looks like the Toyo one just lighter weight..and a 16 buck savings. When I get my car BACK to being road worthy (Thanks Petros!)--I will be able to start working again and will buy the Toyo brand..maybe :wink:
If you always want to have the car running, I have found there are only a few spares I need to carry when I go on cross country trips. I considered what would stop the car from running if it failed. The fuel pump, the alternator, the distributor assembly, that is about it short of throwing a connecting rod in the engine or bundling up the trans. You can drive home with leaks, without a starter (roll start it, happened on one trip, I just always got stopped at gas stations with down hill runs from their pumps). Most other failures will still allow the car to run, even if poorly, like a vac leak, exhaust leak, mushing brakes, etc. all will still get you home, even if running poorly. The distributor contains coil, ignitor, pick-up, etc. in all one unit, it is also useful for diagnosis, if spark trouble you just swap the whole assembly out to test everything in the system.
I also carry a complete tool kit as well. I have never been stranded except when the trans failed, I have even done head gasket replacement during a cross country road trip.
celtglen
Post by celtglen »
Petros wrote:If you always want to have the car running, I have found there are only a few spares I need to carry when I go on cross country trips. I considered what would stop the car from running if it failed. The fuel pump, the alternator, the distributor assembly, that is about it short of throwing a connecting rod in the engine or bundling up the trans. You can drive home with leaks, without a starter (roll start it, happened on one trip, I just always got stopped at gas stations with down hill runs from their pumps). Most other failures will still allow the car to run, even if poorly, like a vac leak, exhaust leak, mushing brakes, etc. all will still get you home, even if running poorly. The distributor contains coil, ignitor, pick-up, etc. in all one unit, it is also useful for diagnosis, if spark trouble you just swap the whole assembly out to test everything in the system.
Great suggestions P :D
applewew
My tercel:: 1985
Post by applewew »
Thanks a bunch for the tips, I'm definitely going to keep that stuff in stock.
I also carry a tube of Permatex form-a-gasket sealer, some fuel line, a spare fan belt and a timing belt, sometimes a water pump (but they seldom fail, and even than usually starts as a leak). And a tube of hand cleaner and a roll of paper towels! ;-)
Paper Towels
Never Leave Home Without Them!
My wife actually prefers the baby butt wipes (moisten towels), called "Wet Ones". When we are on the road and I need to wipe my hands off, I lean over and say to to her "lay another Wet One on me momma!"...she is not amused.
I prefer plain paper towels.
celtglen
Post by celtglen »
Petros wrote:I also carry a tube of Permatex form-a-gasket sealer, some fuel line, a spare fan belt and a timing belt, sometimes a water pump (but they seldom fail, and even than usually starts as a leak). And a tube of hand cleaner and a roll of paper towels! ;-)
Of course IF you carry a part--you won't need it--- :shock:
