The tercel has started to hesitate and bucks horribly when going up hills. It was fine until a couple of weeks ago after I went down a steep bumpy road (it started to buck on the way back up but once I got to the top of the steep part it was fine). So the bucking only seems to happen on hills, no matter how warm/cold the car is. I have a Weber that was poorly installed so it might have something to do with that
Photo 2
I did some reading and found a couple of threads on the topic:
https://tercel4wd.com/forums/viewtopic.php?f=4&t=7796 - 'Vac line attached to nothing' - A vac line not connected to the MC (also has a link to FSM vac-line drawing).
https://tercel4wd.com/forums/viewtopic.php?f=4&t=7960 - 'Car hesitates and stalls on Hill when cold' - Car hesitates on hills and when cold. Was told to check the vac lines and clean the dizzy.
https://tercel4wd.com/forums/viewtopic.php?f=4&t=7745 - 'Weak acceleration, lacking power uphill, occasional backfire' - Same problems I am having (including the occasional backfire) and DLB cleaned the dizzy.
https://tercel4wd.com/forums/viewtopic.php?f=2&t=7251&p=54078 - 'Hesitation when accelerating' - Poor acceleration and could be vac leak ro auxiliary accelerator pump.
So I am planning on:
-Checking the vac lines to see where this random line should go.
--> I just checked and there was another line that connected to nothing. I looked at the vac line drawing and it looks like i have to connect it to the random line. Time to take it for a spin!
-Check the dizzy and give it a cleaning anyways (is there a write-up somewhere? I tried search but no luck)
-Check the aux accelerator pump
In the meantime, can someone easily identify this random line and tell me where I should stick it?
Thanks,
Scott
