Engine Nearly Stalls
dug320
Post by dug320 »
Not sure why but well letting off the gas and disengaging the clutch my engine nearly stalls. When in neutral I can rev and let off the gas and it never happens.
Vaccum leak? I checked everything but I could have overlooked something small.
Any guesses??????????????
arbskynxnex
Post by arbskynxnex »
I would check the Throttle postioner on the carb. IF I remember correctly, when you let off the gas, the TP engages so the throttle comes down slower and doesn't stall. Its in the factory manual as to what it does exactly and how to adjust it, its in the Fuel system section I think.
dug320
Post by dug320 »
I thought it could be. I moved it up and down with no change :(
Think that's the one on the front of the carb that you need to remove the air cleaner to adjust...if I adjust mine to specs it won't idle down right...so I have a similar problem right now.
Might increase your idle speed by 200 RPM or so? I like easy fixes.
dug320
Post by dug320 »
I wish it was an easy fix. I don't have that much time to fix the car right now. But I really need the car to work.
I have a few hours today so I a going to go through the system.
Cheers
dug320
Post by dug320 »
Ran through everything. It looks the vacuum advance is not working properly.
Lack of vac advance would probably cause that...I couldn't find any aftermarket dist diaphrams though. Might try to get a quote from the online Toyota dealer?
dug320
Post by dug320 »
Well I thought I had fixed it. But I think there is some dirt in the vacuum lines. How it got there is beyond my comprhension. I think I will do a vacuum check on the advance.
dug320
Post by dug320 »
I did the test on the advance. That was not the problem.
The stumbling block in solving is the lack of consistancy in the stalling. No exact way to reproduce the stall consistantly.
hornett22
Post by hornett22 »
throttle shaft sloppy? the shaft at the bottom of the carb,can you wiggle it ,is it loose? if it is then you have a vacuum leak in a bad location.i usually can match up bushings at the hardware store.you will have to drill the plate out for the bushings.your other option is to find a carb with less miles or a weber.
there is only one jeep.and that is one too many!
dug320
Post by dug320 »
I will check it out.
It is so inconsistant and that is what makes it sooo frustrating to diagnose.
:ph34r:
Check the equivalent gizmos on the 4WD 3AC?
"I have a 87 Tercel that was getting pretty crappy gas mileage and ran very rough, it would almost and sometimes would stall out at stop lights. I took it the Toyota dealer and they repaced two valves on the outside of the motor, the VSV and BSC valves. I never knew they existed before that. After that + a tune up and the car ran smooth as the day it was made, and I got back all the gas mileage (around 40 MPG). If you think you need them I still have the bill with the part numbers."
hornett22
Post by hornett22 »
the 4cyl trucks use them too.
Post by Chris »
I know what a Vacuum Switching Valve is, but what is a BSC and what does it do? Was it added in 87? None of my five Tercels from 83 to 86 have it that I'm aware of (at least by that designation).
Thanks
dug320
Post by dug320 »
The only thing close is a TVSV. No BSC
