Problems turning
Foryst
My tercel:: 1984 toyota tercel sr5 wagon 4wd
Problems turning
Post by Foryst »
This just started happening recently. If I take a turn the car will start skipping. With or without gas. anyone has info on whats wrong? Thanks
Re: Problems turning
sounds like it is in 4wd on a hard surface (you do not want this )
when you turn the outside wheels travel farther than the inside wheels
they try to catch up
hard on drive train
can you describe what you mean by skipping? like hopping along fast, or kind of binding and eventually giving?
Foryst
Post by Foryst »
A binding and giving out. Even not in gear when I turn it happens. Something catches then goes out
check for free play in the steering wheel. i can't remember how much there is supposed to be but just check the FSM or even your owner manual. i would also jack up the front end and try turning the wheels by hand, mimicking steering. check for play. if there is play, look and see where it is occurring. if it's in the inner or outer control arms, that's easy to remedy. if you can't see any play, it might be in the steering gears or u-joint. maybe pop the hood, reach in and turn the steering wheel back and forth, and watch from the side to see if the u-joint is obviously hooped.
did you bump anything recently? when did you last work on your front end? power or manual steering?
Foryst
Post by Foryst »
It happened after I took a turn it wasn't too crazy in my perspective :) and power steering thanks
skipping? skipping? what does that mean? not sure by your description. Is wheel locking up? check wheel bearings. Does it to both sides or one side only? does it makes any noises when it happens. does it happen always, or just sometimes?
Foryst
Post by Foryst »
Skipping like the wheels will go and then not catch and gets the noise I can feel the whole engine moving. It only happens when I turn or try to gas hard
danzo
My tercel:: '86 SR5 6 speed
Post by danzo »
Sounds like you are talking about an engine misfire? Does it happen only in 4wd? You need to be more specific so we can help.
It is possible the steering is binding, and causing the issue?
There is a small universal joint on the steering linkage, on the steering shaft right above the rack and pinion. Sometimes these can bind up when worn out. Try putting a lot of lubrication on it and see if the problem goes away. These are hard to find if this is the problem, must go to wrecking yards to find a good one.
what would he use to lube it, peter? is lithium grease too light? i'm wondering for future reference in case i ever need to do this.
rer233
My tercel:: Multiple
Post by rer233 »
i've had good results using wd40 (it's thin enough to penetrate the joint caps) followed up with a shot of kleer lube (thick enough to hang around for awhile- it's kind of like snot in a can.) as a preventative measure, i give my steering joints a shot of kleer lube at every oil change. never much cared for white lithium- tends to turn to a white powder over time. 'course this only works BEFORE the joint develops play- at that point it's replacement time! bought a new replacement shaft from the dlr for my '84 for about $120 (that was 10-12 years ago- may now be NLA.) hope this helps.
I use LPS, but it is light so you have to apply it often. ATF also penetrates well, but also is very light. It is not supposed to be serviceable, but it might be possible to take it apart and lube it with moly grease and press it back together. I have several worn out ones, and a good u-joint from a wrecked MR2 steering column (different assembly, but the u-joint is the same size), I might try and swap them out if I can not find a replacement.
The assembly is no longer available, but I know of a machine shop that might be able to find something that could work. If so we might have a way of having these done on an exchange basis.
smokerx
My tercel:: 1983 SR5 wagon 4WD stock 3A-C Federal
Post by smokerx »
Just solved my same problem in this thread.
https://tercel4wd.com/forums/viewtopic.php? ... 4&start=15
