1992 Toyota Corolla Wagon AWD (nanaimo, BC)
the tercel's cousin. manual trans. i still have such a crush on these things.
http://www.usednanaimo.com/classified-a ... D_16372357
c_j
My tercel:: T4WD#4: '86 SR5 6-speed, original Barto lift & steel bumpers & winch, also 95Amp alternator
Re: 1992 Toyota Corolla Wagon AWD (nanaimo, BC)
Post by c_j »
I wonder if that 5spd trans would still have the EL gear?
i don't believe the corollas had an EL gear. i'm not positive though since the only one i had was an automatic. regardless, they're still pretty nice.
This car has a regular 5 speed gear cluster that I think is similar to the front drive set up (transvers engine and trans installation, totally different than the Tercel4wd). It has a center diff and a rear power take-off for the rear axle, it is push button/solenoid actuated. So it is really AWD, much heavier and does not have the EL as the Tercel.
