Oil Pressure Switch
Turkey
My tercel:: 1985 SR5 Wagon 4WD - Stock
Oil Pressure Switch
Post by Turkey »
I have a 1985 Tercel SR5 4WD M/T with an oil leak. I have tracked it to my oil pressure switch. Before I replace the switch, I need to know if I need to prepare the new switch before installation (i.e. teflon tape on the threads). Can anybody please help me out? Thanks in advance.
Re: Oil Pressure Switch
i quickly looked in the FSM and couldn't find anything there but a copper washer or one of the ones with a rubber inner diameter should be sufficient since it's just a plug similar to the oil drain plug.
how much is it leaking? did it start leaking on its own or did you do work in that area recently?
Turkey
Post by Turkey »
Where can I find a copper or rubber washer to use with it? or am I just being overly paranoid?
The pressure switch started leaking on its own over time. It was at first a small weeping leak that I couldn't track, but now its bad enough that I need to address it. It is leaking at a rate of maybe a quart of oil per 1000-1500 miles.
get a new switch (they go bad and start leaking)
there is no washer
its a taper thread like a pipe fitting
the more you tighten the tighter it gets
a little gasket compound to the threads is ok (non-hardening type)
I thought I had a similar leak a few years ago and bought a new switch - turned out I did not need it, so bankrolled it for the future. In 2007 it was only $4 from AutoZone. It is a DuraLast (house brand) part # PS123. It was the switch only - no washer.
Turkey
Post by Turkey »
I only ask about thread preparation because I know that tapered pipe threads are designed to have some form of teflon tape for proper sealing.
I have used the tape before, but I find the non hardening form-a-gasket easier and works well. Either is okay, I would not trust it not to leak without the risk of overtightening it without a sealant.
Turkey
Post by Turkey »
I changed the oil pressure switch today. My question was answered after I had the new part in my hand. There is thread sealer compound on the threads of the new switch. You can see it in the attached picture; there is red material on the threads. See attached.
Also have a picture of the old one in case someone was interested in seeing that one.
The body of the pressure switch is a metric hex, I'm sure, but the only tools I have that are large enough to grab it are standard, as it is between 1" and 1-1/16" I could get a 1", 12 point socket to fit over the body, but not 1" open end. The open end had to be 1-1/16". Also, the driver's side engine mount covers the oil pressure switch where it is located on the engine block. I had to loosen the alternator, remove the top alternator bolt and swing the alternator out of the way as far as it would go so I could get to the pressure switch. I used channel lock (possibly trademarked named *) pliers to get the old pressure switch out and I used a 1-1/16" open end wrench to tighten the new one.
