A recent interested buyer was very enthusiastic about this car and the price, but backed out until after he moved his family. So I think the price is within range of what good examples are now selling for. No rust at all, it was a California car its whole life. Never wrecked or even dented. all original too!
see the listing here:
http://seattle.craigslist.org/sno/cto/2566413841.html
ad reads:
One of the best little classic 4wd cars ever built, very reliable, great fuel economy and 4-wheel drive. It is in excellent condition, all original, with relatively low miles 169,000. It was a California car its whole life, no rust at all, never wrecked or even dented. Excellent near new all season tires on stock steel wheels with original Toyota hub caps (extra set of factory alloy wheels available if desired). It also has the center console with the inclinometer, has full instrument cluster with tachometer and temp gauge. Original Toyota AM/FM radio. The interior was recently removed and cleaned and than reinstalled. The dash and all seats in great condition, driver's seat only has two tiny holes on the side. It smells good and clean in the car. All the glass is excellent (no leaks, chips or cracks). Exhaust system is in excellent condition. All ball joints and suspension rubber in good condition. 4wd works excellent, as does the trans (all syncros good, no whine or gear noises), it has the 5 speed plus the Extra low granny first in 4wd. Good battery. This car also has the optional larger double row radiator.
Runs very smooth and quite, better than most. List of stuff that was replaced within the last 2,500 miles...
-New front semi-metallic brake pads, new rear shoes, rebuilt rear brake cyl.
-new passenger side inner tie-rod (Beck/Arnley)
-new intake/exhaust manifold gasket
-new carb mounting gaskets
-new pcv valve & grommet
-replacement used distributor
-new fuel filter
-most of the vac hoses have been replaced
-spark plugs replaced a yr ago (NGK), and new NGK spark plug wires
-new EGR mounting gasket, replaced the EGR vacuum modulator with used one
-used replacement TVSV valve
-new valve cover gasket & grommets
-New thermostat and antifreeze and new radiator hoses and radiator cap
