4AGE swap into 85 4WD
shogun
Re: 4AGE swap into 85 4WD
Post by shogun »
petros im looking for flat pistons 78mm you know where they can be found (sorry for the thread jack synth)
ewsoares
My tercel:: 1984 Tercel 4WD
Post by ewsoares »
I had not seen the MR2 brake upgrade, looking for it now. Will this make it easier to brake? Seems like I have to push pretty hard and constant to stop. I dont remember it being that hard with my first SR5, maybe my power booster is going? I believe I do have a vacuum leak somewhere, fluctuating idle by about 500-800 RPM roughly. And idle will take off to about 1500 RPM and stay there until I rev engine a bit. I am curios on the offered price in case I want to do the mod, pm or respond here. Also living in colo springs I am on a lot of inclines, hills and waiting in traffic it takes a lot of pedal pressure to hold the car from rolling back.
The stock brakes are way too light for this car, they are the same as for the fwd hatchback. You can overheat and warp them just making a hard stop coming down a mountain pass (I have twice!). You will make it stop better with the change in master cylinder, and make the brakes less heat sensitive by changing to vented front disks. Here is the thread where I instruct you how you can do that: https://tercel4wd.com/forums/viewtopic.php?f=7&t=4998
Shogun; The last flat top pistons for the 3a I got was from Sealed Power, I do not know if they still make them since it was over 5 years ago. I can get you part numbers if you want to look.
shogun
Post by shogun »
@petros thankyou it would help me a lot
i raced my tercel and i can attest that brakes are inadecuate, good fluids a good set of hawk hp plus pads and everything up to spec it will out break many modern cars, with the update of course i did it like 6 or 7 years ago
ewsoares
Post by ewsoares »
Now I need to take a trip to the junk yard. I like that place anyway, lol. I myself think it would be cheaper for me to replace the crankshaft than weld and redrill flywheels. Since I am inclined to rebuild whatever 4age I get for my tercel as well as I think most machine shops take too long and might be a useless expense if im rebuilding anyway. So do I have to go with fuel injection or can I keep the carb when I do the swap? whats best? I dont mind the FI although I have always been a fan of carbs. Would save some work if it didnt matter. By that point though its probly not that much more work to do the fuel lines I imagine?
EFI is way superior to any carb set up. IT would be a shame to put a single carb on a 4age, unless you go duel side draft solex (there is a kit available to convert the 4age to duel side drafts, shows up on ebay somethings), but it is big bucks, more than the engine and cars costs. I would go with the EFI just for lower cost and better driviablity, economy. However, lifting the Tercel hood and seeing duel side draft carbs on a twin cam engine would be hot.
You likely can make a 4age head work on a 4afe or 7afe short block, and that would save you from messing with flywheel and crank issues, both have the same 6 bolt flywheel pattern as the 3ac engine.
ewsoares
Post by ewsoares »
So it sounds like I will just make a list and start getting piece by piece until I have it all, I would much rather just swap a head especially if I would be rebuilding it anyway.
SynthDesign
Post by SynthDesign »
@ewsoares, I was just in Colo Sprngs for the PPIHC. As for the list it's a bit lengthy but a custom flywheel and high pressure clutch and plate are a must.
The AW11 Brake booster is one of those "MUST" upgrades. 100% worth it in every aspect! Already installed for my swap.
A good machine shop is worth their weight in Beer tips. Seriously! 65% of the cost of my build so far went to the machine shop Shameless Plug, Kirt at East Side Machine in Redmond WA. I'm expecting my engine to go hard and last long. Also this is the 13th engine I've had him work over now and never a problem.
2005 Toyota Sienna, work van
85 Toyota MR2 (Blu)
83 Mazda RX-7 Mariah Widebody
SynthDesign
Gettin closer
Wiring, Exhaust, Fuel line/Pump, throttle cable and......
85 Toyota MR2 (Blu)
4wdchico
My tercel:: 1985 tercel 4wd
Post by 4wdchico »
ewsoares wrote:Now I need to take a trip to the junk yard. I like that place anyway, lol. I myself think it would be cheaper for me to replace the crankshaft than weld and redrill flywheels. Since I am inclined to rebuild whatever 4age I get for my tercel as well as I think most machine shops take too long and might be a useless expense if im rebuilding anyway. So do I have to go with fuel injection or can I keep the carb when I do the swap? whats best? I dont mind the FI although I have always been a fan of carbs. Would save some work if it didnt matter. By that point though its probly not that much more work to do the fuel lines I imagine?
The 4age engine has a forged crank and much better rods than the 3a/4a setup. So if you want to enjoy the RPM potential of the 4ag head w/o worrying that your cast 3a/4a crank is going to grenade, I'd suggest sticking with the forged crank and have the flywheel modded.
SynthDesign
Carburetion VS Fuel Injection is a major time difference. If I wanted to go Carb'd, the engine would be in and running. I'm roughly 27 hours into wiring play. The reason I'm going for fuel injection is reliability, fuel economy and durability. Most of the people running a Carb'd 4A-GE get around 17 to 19 average, burn up valves and put down quite a bit more HP. The stock AE86, Corolla GTS drivers see 32mpg average with the fuel injection and the heads have shown to last 200K w/o a problem and put down a modest 120 to 140 HP.
That said, my choice and my wiring HELL.
Everything with blue tape stays including the ECU. Every wire going out has to be added to the T4WD system
85 Toyota MR2 (Blu)
Synth - you (and several others) just - blow me away!
SynthDesign
Got a good portion of the wiring tied up. Gotta yank the Tercel dash and a few panels... still workin out fuel pump and exhaust. Also need to find a Supra alternator in the same amp-age and plug configuration as bracket is on the other side and the mount is the same(easier than fab'in a big tensioner bracket).
I snagged a 90 Tercel throttle cable and adapted it to work in a T4WD with the 4A-GE engine
I was temped by my Toyota Guru to yank all the emissions stuff. Only issue would be a check engine light, which I just found out I will have to add... somewhere..
I emailed the SCCA sanctioning body just to make sure. Another option might be to run an MR2 ECU which I have a few of.
I took Monday the 8th off to drop the engine in. Hopefully a bit of eye candy to show in the coming month.
85 Toyota MR2 (Blu)
SynthDesign
So Monday the 8th came and went with no time for the swap. Last weekend I did get a bit further.
Much easier to install and pull the engine/trans w/o the front cross member
The engine is going to need to be dropped a bit. I'll start with a 10mm cross member spacers like I did in the general and see what happens. Also maybe try a thinner engine mount as the rack has plenty of room over the oil pan.
Lots more to come :)
85 Toyota MR2 (Blu)
nice install. how did you get the trans housing so clean? did you have a shop rebuild your trans? I used degreaser on mine and at best it looks like dull and dark aluminum, with lots of 'dark patches'.
