Cheap parts in BC !
gerviswaddell
My tercel:: 1985-
Cheap parts in BC !
Post by gerviswaddell »
Hey there,
My dead tercel is resting in the driveway (wasnt able to locate a replacement in time) and it looks like we will be moving away soon. Basically the car has a lot of new or reman parts on it which have only seen about 6000km of highway driving (from Toronto to Terrace bc, and then some highway driving around here before she croaked).
The parts which I can think of are:
Inner and outer Tie Rods (left and right)
Ball joints (left and right)
CV joints (left and right)
Rhinopack clutch kit
Straight (original) rear axles with new main bearings
New Block heater (probably used about 30 times)
Coolant Temperature sensor (upper one, cost me $30)
Complete upgrade kit for vented corolla disk brakes (new rotors, pads, and custom cut adapter plates, calipers and hoses from a 93 corolla)
Master Cylinder (reman)
Rear brake cylinders
The car rusted out and the control arm mount broke loose, it has just over 200,000 KM on it.
Non-new parts which you might find valuable are: Manual Transmission Runs fine, some whine , everything works.
Most plastic (tail lamps, driving lights etc)
I have two used alternators which are functioning nicely. Two distributors ditto.
Basically, I will have to junk the car if I don't sell any of the parts, due to my relative isolation in Terrace bc. I will be driving through northern bc, into alberta and then down into the USA. Probably north dakota over on the I 90 or something.
I would like to get a fraction of my money out of the parts, but mostly would rather not see them go to waste. If I don't have any interest in them, I would rather not spend the time pulling them all off.
So....let me know if you want any of them and we can work out a price (It will be reasonable, I assure you) The more parts you want, the better.
I should also mention that I have a set of Nexen Winguard studded winter tires on 13" rims which have seen roughly two months of VERY snowy driving (so minimal wear). I need them gone also.
Ok, let me know if you want anything.
Thanks,
GW.
Re: Cheap parts in BC !
PM sent.
toughtercel
Post by toughtercel »
Terrace bc, is that where the car locate now .
gerviswaddell
My tercel:: 1985-
Yes, the Car is in Terrace. where are you located?
gerviswaddell
My tercel:: 1985-
Here is a link to the Kijiji Posting for the car: Some additional details in there. (and some parts I forgot to list)
http://princegeorge.kijiji.ca/c-cars-ve ... Z292147068
toughtercel
I live at Surrey part of "Lower mainland" that coverage from Horseshoe Bay (west side)to Chillwack (east side)
So_Powerful
My tercel:: 1985 Toyota Tercel 4wd
Post by So_Powerful »
I noticed you said you are driving down through Alberta. Would you be stopping through Edmonton? If so, do you have the ability to tow the entire car with you on your way through. If so, I will buy the whole thing.
