Two questions:
Re: Two questions:
you crack me up! "it's really boring". it s not bad if you skip ahead to get to the important parts, I am not sure it was really necessary to show how you remove the lug nuts for example. If you edit it some, and perhaps do a voice over of the steps it could be shown in perhaps 8 to 10 min or less. As I stated above, I have not found it necessary to remove the brake caliper or the steering tie-rod. Good effort.
Re: Two questions:
davidlucasbarnes wrote:xirdneh, unless your glass is damaged anyway i don't think you will need to replace it. it's usually just the seal around the glass that gets old and cracks.
its cracked up quite a bit
Re: Two questions:
check around on windshield prices, many of the mobile glass repair guys would do it for well under $200. I just got a quote for about $160 for a Tercel windshield from an ad off Craig's list. I had the Corolla all-trac tinted windshield replaced for only $178 by one of the independent mobile glass repair guys (he was a Ukrainian immigrant, he did a great job) about 2 years ago.
So_Powerful
My tercel:: 1985 Toyota Tercel 4wd
Re: Two questions:
Post by So_Powerful »
Unfortunately I do not have the time or talent to edit such a video. I know there are different variations of methods to remove the half-shafts. I just did it the way I thought best. If someone else would like to edit the video. I could e-mail the files. I just don't have the time right now.
