Looking for a good unit, I have broken levers inside of it. LMK what you got.
Thanks , Casey
http://www.caseys@murray-ky.net
WTB Heater Control Unit for 85 Terc with A/C
No replacement for displacement......
Re: WTB Heater Control Unit for 85 Terc with A/C
bump!
Hi there. My friend had also encounter some broken levers of his heater control. At first, he thought if it's possible just to replace the levers or either fix it in someway but after bringing his car to a workshop, the mechanic who check it suggested replacing the heater control with a new one. So my friend has no choice and had bought this a/c and heater control online. Well, you can try checking that if ever you are still in need of the heater control unit.
I should have this part in a parts car......... I'll check in the next few days, and post or email you.
need anyhing else?
need anyhing else?
8liter wrote:Looking for a good unit, I have broken levers inside of it. LMK what you got.
Thanks , Casey
if your refering to the levers in the dashboard
after replacing levers put some drops of oil on the water control valve under the hood by the firewall on passenger side
and work that arm back and forth to free it up
that may have been what caused your problem
Yea. A driverside fender that's not rotted.... Thanksjemmy3 wrote:I should have this part in a parts car......... I'll check in the next few days, and post or email you.
need anyhing else?
Thanks , Casey
iS YOUR TERCEL 4WD?
i THINK THE 2WD [EDIT: FENDERS] ONES ARE DIFFERENT...
EMAIL, OR PM ME FOR A FASTER RESPONSE... sorry, caps locked.....
8liter wrote:Yea. A driverside fender that's not rotted.... Thanksjemmy3 wrote:I should have this part in a parts car......... I'll check in the next few days, and post or email you.
need anyhing else?
Thanks , Casey
