My converter looks to be ?? years old...with the heat shields falling off.
Downpipe has a leak (temp fix) where it is mounted after the manifold. Now have 2 other leaks at points further back.
Plan on just buying the downpipe and a generic converter with associated gaskets....and then going with 2" ID (?) stainless flexpipe into my current glasspack at the rear.
Looks like Advance AP has the best prices...maybe.
In the process of finding and ordering parts...added comments:
* downpipe to manifold gasket @ $2. AdvanceAP
* downpipe with 1 3/8" ID (old one is same ID & OEM is also the same?)...Walker @ $32. AdvanceAP...a lot of restriction with this pipe..the old one is the same. This is a doublewalled pipe.
* generic converter @ $43...11" long with 2" ID pipes in/out. AdvanceAP...should be a freeflow converter due to pipe size...has a small heatshield only on one side...I'll try to make one...if you drive in dry grass, it's very important to have a good heatshield.
* 10' 2" ID SS flexpipe @ $43. JCWhitney
* several 2 1/8" exhaust pipe clamps....will use regular steel rather than ss steel...pipes are cracking...current clamps OK
* extra hangers.
* use current non-louvered glasspack muffler...they last a long time
Overall cost around $140...everything from header to ss flexpipe will be welded?...clamps from there on back
When looking at the old commercially intalled exhaust...I see problems:
* not enough hangers installed (for a solid pipe) resulting in the pipes cracking.
* if the converter or other part of the system hits the ground...the solid pipe will have to flex...resulting in eventual cracking?
* pipe has cracked in 2 places at mounting points due to the load not being spread enough...or from welding stresses. 1 additional crack at back of converter due to lack of support.
* clamp in center was not installed for best ground clearance.
My improvements:
* Add as many supports as needed.
* Use the SS flexpipe to reduce damage offroad and to allow free flow for exhaust.
* Make sure all clamps and converter are installed for best ground clearance.
* Be sure that exhaust tip won't get caught under rear bumper when it drags.
What diameter to use:
<a href='http://www.hondalife.com/modules.php?na ... d=4&page=2' target='_blank'>http://www.hondalife.com/modules.php?na ... &page=2</a>
"60HP (at the crank) per square inch of (cross-sectional) flow area.
This 60HP/in^2 is to get you in the general vicinity. It also is based on the inside diameter of the tubing not the OD."
So looks like the Toyota people knew what they were doing by using a 1 3/8" ID downpipe. My system basically has the narrowest areas of 1 7/8" ID in and out of the converter and at the muffler...the rest is 2" ID flexpipe.
1 5/8" ID / 1 3/4" OD all the way back thru a free flowing muffler is the best size?
Before installation:
Got the exhaust installed. No major problems...just a good bit of work.
Oiled all bolts 3-4 times in the 24 hours before starting.
Made a heatshield with about a 1/2" airgap for the generic converter (was inadequate as sold) out of light gauge steel and had it wire welded onto the converter. Also had the converter welded to the downpipe and a 2" OD pipe welded on the back.
Made sure all clamps were put on for max ground clearance....u-bolt ends to the side.
Only potential problem is the nearness of the exhaust to the gas tank where it is approaching the muffler....there is a need to have a serious bend in the exhaust pipe at this point to clear things...flexpipe will only bend so far....probably OK. I used some foam/alum and alum sticky sheet type material to insulate the plastic covering the tank on this corner.
The old converter was not really plugged at all...but not sure if it actually removed any pollutants or not.
Complete exhaust with glasspack could be done for $150-160.
Does this SS stuff last?
This section was at the back of a car & in front of a muffler (highest exhaust rust area?) for about 3 years...notice that the regular steel pipe has rusted out...the rust you see on the stainless is from the plain steel...good as new except for the clamp dents?
Need a pipe expander to get the dents out to reuse this.
