Ordered 0901 - Butler received from warehouse and shipped 0903 - received 0907 (Labor Day 0906).
OE part numbers, as obtained from Butler Toy September 2010.
The first price is regular OE retail - the second is Butler's. Note that all are quite competitive with AM parts and better than other Toy dealers.
04421-12011-77..Bearing kit...................57.73.....2 @ 43.30.....86.60
42454-20010......Bearing retainer LH.........8.46.....1 @..6.35.......6.35
42424-20010......Bearing retainer RH.........8.46.....1 @..6.35.......6.35
42185-52030......Gasket axle housing end...7.89......2 @..5.92.....11.84
42425-52030......Gasket to retainer..........2.43......2 @..1.82......3.64
94181-11000......Locking shoulder nuts......1.66......8 @..1.25.....10.00
90311-42055......Oil seal.......................5.56......2 @..4.17.......8.34
Total USD 133.12 for OE parts vs. USD 177.42 regular OE pricing.
While irrelevant - the Toy replacement for the axle gasket is plastic instead of metal (I guess it discovered that steel rusts...) and the same plastic is used for the retainer gasket instead of fibre.
EDIT 03/20/2012 - I had transposed the numbers for the OE bearing retainers; they are now corrected.
A local garage charged $25 to remove/install the bearings and retainers.
I ordered all-new; I don't want to do again in ten years. The left seal had failed, causing a good-sized oil leak and the right bearing was quite loose internally and clunking and was solidly rusted * into the housing from the blocked retainer drain that Petros had warned about back in 2007. I would certainly recommend all heed his advice on cleaning these when doing a brake job - or even checking this before the Winter.
* If rusted in place, I would strongly suggest squirting a penetrant between the outer retainer and the brake backing plate and tapping the former with a hammer & punch to break it loose before using the slide hammer. Overly zealous yanks on the slide hammer could pull the retainer and backing plate as a unit, resulting in some brake line problems...
P.S. And "No," I receive no lollipops from Butler
► EDIT: ◄
Petros' thread on clogged drains - https://tercel4wd.com/forums/viewtopic.php? ... ake#p22409
