turn signals/springs
- My tercel:: No tercel. (stolen)
hey everyone i have just done a cool change to my car i have changed the turminals for the parking lights and that turn signals noot the parking lights are my turn signals and my trunsignals are my parking lights. but ui have a little problem my turnsignals are flashins extermly fast now but when i put my 4way flashers on thay blink slow what can i do i would love to keep this setup but a slower blink. what to do??????
Re: turn signals/springs
not to change the topic but i would also like to know how to take the rear bumper off i have got the front off but cant seem to figure out how take the rear off.????
Re: turn signals
rear bumper removal
open back door
push back rug
pull rubber plugs on both sides
that will give you access to the 4 bolts
open back door
push back rug
- splatterdog
Re: turn signals
Try a heavy duty(variable load) flasher, typically used for towing. They don't care about bulb count to flash correctly.
Re: turn signals
where would i find such a thing??
- My tercel:: 85 Tercel SR5 4wd
Re: turn signals
sound like a cool mod. based on my limited knowledge of flasher theory i would say that the difference between the amp draw from the front to rear is causing it. if the bulbs from the parking lights have the same draw as the original signal lights it should act the same right? maybe you could retro fit the parking lights with the signal bulbs/ find bulbs that fit that draw more or less and beef up the circuit or find a vehicle with the same draw on all four corners as you're current set up and use that flasher.
Re: turn signals
ok that sound easy enought but im cerious about that heavy duty variable load flasher?
- splatterdog
Re: turn signals
They are right next to the regular flashers. The HD are always bigger. Any reputable parts supplier should be able to set you up. Maybe even wallymart. They are about $10.
As far as where the flasher is on the car, can't remember. Haven't had any flasher troubles yet. Luckily yours still works so just follow the click....
Good luck!
Good luck!
Re: turn signals
ok thankyou i will look
Re: turn signals
ok i have not gottin' to the flasher yet but im working on it i was just woundering what rear springs i can get for my car that will rase the rear by 1" or 2" at the max.
Re: turn signals/springs??
i was also woundering if any one has tryed to rase the front of the tercel with a set of diffrent struts like the carolla or the all track??? i need help plz
search the threads, Barto's build thread has Nissan Pathfinder rear springs (I just recently bought a set for mine at the yard), and most lift the front by making a shim spacer for the top of the strut. Do not lift the front too much, it changes the angle on the CV joint and the steering link. Lift the front more than about 1" should get other changes to keep everything in alignment.
There is also a thread on other front struts that might fit, the Corolla All-Trac strut is larger diam and about 3/4" longer, and should bolt up with some minor changes.
what year pathfinder or dose it mater? because there is only to at the pick N' pull that is near me an if i remeber right thay are a 92 and 80 something.
ok so i got my shocks in and now the car has a bit more of a solid feel to it but cant wait till i get the spring on friday well here are the pictures.
The pathfinders made from '86 to about '94 had a separate frame and body, the later ones had the unibody chassis. Any of the earlier ones would work. The earlier 2 door model ('86-89) might have a lighter spring which I would suggest, or you have to get longer shocks (or cut the a coil or two off the spring) since it will raise the rear 3 or more inches. Go check out the Barto's Build thread.
