I got my hands on an Echo motor...
emmahumpfritter
My tercel:: 1985 tercel 4wd
Post by emmahumpfritter »
Does anyone know if the echo 1.5L VVT-i will bolt up to the tercel trans without an adaptor? The echo is more/less totalled from the rear (perfect donor). I know I've asked this question elsewhere indirectly but can't remember the exact answer. Thanks, Brenton
260K with no end in sight....
SynthDesign
Re: I got my hands on an Echo motor...
Post by SynthDesign »
No dice on the 1NZ-FE motor. It isn't compatible with transmission or the fuel system.
Way too much work to even try.
2005 Toyota Sienna, work van
85 Toyota MR2 (Blu)
83 Mazda RX-7 Mariah Widebody
emmahumpfritter
Too bad, would be a great motor for the tercels I think. Thanks for the answer eh.
That is a nice modern engine with EFI, 16-valve head, and a distributorless ignition (all the things I want for my Tercel4wd!), but it is a completely new design, and I thought I read that it is made in Korea by Hundai for Toyota. The Echo replaced the Tercel as their entry level car. A nice engine, but not worth the effort, there are other engines that are easier to adapt that have these features.
SynthDesign
I got to look at one out of the car @ Toyota of lake City. Defiantly No Dice.
Nice compact little engine, but no way to make it work with any A series compatible trans. The oil pan would sit where our front dif. is. Custom bottom end and transmission plate adapter.... Way too much work.
It is a cute little engine though.
85 Toyota MR2 (Blu)
