thats all i heard about , bolt right up just need a donor car and have the exhaust fabricated......NOT
im back to working on the tercel. i had way to many projects going on so i am selling the other stuff and finishing the tercel. im at a point i am confused, how the heck do i mate the 4ag to the tercel transmission? the 4ag flywheel is a lot bigger than the 3ac's, it wont fit in the bell housing i looked at shaving the inside of the housing and its to much. the top of the flywheel will fit but the bottom of the bell housing needs a lot more room. im at a loss of my options at this point. im clueless, someone please help..hahaha 20valve, didnt you do this before?
quote from 3ac-power
can the bellhousing come off? the bell housing is aluminum, a pro has to wield on it. the exact problem im seeing is the part of the bell housing that has to be shaved down is the bottom where the part of the trans goes to the front wheel drive axles.You would use the 4A-GE clutch. The input shaft spline is the same as the Tercel's. With a 200mm flywheel you may not have to grind out the bellhousing and if you do, you will have to weld support around it because it's pretty thin.
little bit more looksee and i can use the same flywheel off the 3ac engine. i just have to swap the hole contraption that the flywheel bolts on. they look identical.
