Can anyone send me a pic of the fuel pump heat shield? Nearest junkyard with a 3A/4A is 3 hours away and the car is 6 hours away. Need a pic for the junkyard to figure out if they have it.
packratt
Fuel pump heat shield
- splatterdog
Re: Fuel pump heat shield
Go to rockauto.com and lookup a fuel pump spacer. They will have a pic. They also have 2 closeout ones left for $12.57. I got two myself last winter and they were even reboxed Toyota parts.
Autozone lists it under Fuel Pump Block off
Advance under fuel pump gasket IIRC.
The discount ones at Rockauto were gone and shipping brought the regular price up to the local stores.
It seems to me I have seen the same heat sheild on several different models, any that used a carb and mech fuel pump. There is no local yard with any of the models that use the 3ac or 4ac? They came in so many models and different years it is difficult to beleive.
