Alright guys, i'm scared to ask...I have a noise
- Neu
The noise is coming from the backend (rear axle/rear part of the exhaust).
I'm scared my rear axle just went out.
I smell something like ATF after I drove it for a while, there is a clanking noise, which i thought was my exhaust, since it has fallen off and was resting on the axle.
It's an 85 4wd car, and I did submerge a good amount of the car in water, but drove out just fine, think maybe i got water in there?
- Neu
Re: Alright guys, i'm scared to ask...I have a noise
it's like a banging/(I dont want to say grind, but it doesn't actually sound like it)It almost sounds like my exhaust is on the ground, but it's not, I've zip tied the muffler to the bracket (bushing thing wouldn't stay on). The noise comes and goes, but it's usually most of the time at 50+mph. If I hear it below that it usually goes away pretty quickly.
- Neu
alright, there's a lot of fluid coming out of where my brakes are on the driver side...it's actually pooled a little on the ground.
So differential pinion seal?
- Neu
so walk me through replacing the driver side wheel bearing/axle seal. I gotta get this done fast.
Replacing the axle seal is easy, replacing the bearing not so easy.
Pull the wheel
Remove the brake drum
Align the holes between the wheel studs over two of the axle retaining nuts.
Use a 6" extension, ratchet and appropriate size socket to remove the two nuts
Rotate the axle to align the holes over the other two nuts and remove them
Pull out the axle
Pull the seal out of the axle housing, replace with a new one
Take axle to a shop to have the bearing pressed off and a new one pressed on
Insert new axle very carefully as to not damage the new seal
Pull the wheel
Pull out the axle
If I had a guess the sound you are attempting to describe is like metal scraping? As if your dust cover was scraping on your brake rotor if you had disc brakes.. With fluid leaking out its probably a wheel seal, and for that to go your bearing would have gone out. Mine just did the same thing. It's a fairly simple process and the FSM does an excellent job of walking you through it. Do yourself a favor and replace passenger and driver side rear wheel bearings and seals, I got all my parts at http://www.rockauto.com very inexpensive compared to chain auto parts stores around here. (would have been twice to three times as much!) make sure you drain your diff and pull it to make sure its still in good shape while you are at it.
83 T4WD SR5 - In tercel heaven
84 T4WD SR5 - (Rolled) joined the 83
83 T4WD DLX - Daily Driver weber 32/36, Celica/Paseo front brakes, 205/75/14 Snow tires, Lifted, 2.5inch exhaust, "Rebuilt" 3ac.
- Neu
The only problem is i can't find the right bearings on rock auto, they have the front wheel drive ones, but they aren't sealed, so they aren't the right ones.ESI-RStarion wrote:If I had a guess the sound you are attempting to describe is like metal scraping? As if your dust cover was scraping on your brake rotor if you had disc brakes.. With fluid leaking out its probably a wheel seal, and for that to go your bearing would have gone out. Mine just did the same thing. It's a fairly simple process and the FSM does an excellent job of walking you through it. Do yourself a favor and replace passenger and driver side rear wheel bearings and seals, I got all my parts at http://www.rockauto.com very inexpensive compared to chain auto parts stores around here. (would have been twice to three times as much!) make sure you drain your diff and pull it to make sure its still in good shape while you are at it.
http://www.rockauto.com/catalog/x,carco ... rtGroup,14
There are several on this page, Timkin under $12, Beck Arnley for a few cents more.
- Neu
I'm trying to be careful about ordering online, can you give me the part numbers of the ones on that page that'll work? Thank you.keith wrote:http://www.rockauto.com/catalog/x,carco ... rtGroup,14
Edit:
So would these work?
Brake/Wheel Hub : Wheel Bearing
BECK/ARNLEY Part # 0513061
Rear Wheel Bearing, 4 Dr. Station Wagon;All Wheel Drive;2 Per Car $24.79 $0.00 $24.79
Transmission-Manual : Drive Axle Seal
BECK/ARNLEY Part # 0523521 { [Wholesaler Closeout -- 30 Day Warranty (Only 1 Remaining)]}
Transaxle Seal, Drive Axle Flange;4 Dr. Station Wagon;Manual Transaxle;2 Per Car
Transaxle Seal, Drive Axle Flange;3 Dr. Hatchback;Manual Transaxle;2 Per Car
TIMKEN Part # 88506BR
Ball Bearing; Rear Whl; Wagon;4WD
BCA/NATIONAL Part # 88506BR {Ball Bearing Outer Race Radius=0.0402" Bore=1.1811" Outer Diameter=2.4409" Width=1.574" Inner Race Radius=0.0902"}
(4WD); Rear Wheel; (Brg. & Ring)
I verified the Beck/Arnley PN at another web site, but it was $38 there.
- Neu
keith wrote:TIMKEN Part # 88506BR
I need the seal for back there too, both sides, got the numbers for those?
Thanks by the way.
BECK/ARNLEY Part # 0522136
Rear Wheel Seal, 4 Dr. Station Wagon;All Wheel Drive;2 Per Car
TIMKEN Part # 224210
Seal; Rear Whl; Wagon;4WD
BCA/NATIONAL Part # 224210 {Oil Seal / Nitrile / Shaft Size=1.654" Housing Bore=2.165" Outer Diameter=2.176" Width=0.315"}
(4WD); Rear Wheel
(4WD); Rear Wheel
- Neu
BECK/ARNLEY Part # 0513061 { [Wholesaler Closeout -- 30 Day Warranty]}
Rear Wheel Bearing, 4 Dr. Station Wagon;All Wheel Drive;2 Per Car $16.58 $0.00 $16.58
Brake/Wheel Hub : Wheel Oil Seal
Rear Wheel Seal, 4 Dr. Station Wagon;All Wheel Drive;2 Per Car $2.77 $0.00 $2.77
Subtotal
Does that look right? Saving me money if it is! Carquest wasn't 72$ for all the parts, delivered to my door (no extra charge)
This: $53.04
Subtotal
This: $53.04
Rockauto kept hitting me with high shipping rates...better look at those first.
keith wrote:Replacing the axle seal is easy, replacing the bearing not so easy.
Pull the wheel
Pull out the axle
You made the "pull out the axle" step sound so miniscule. I'm having a helluva time getting it to come out. Am I gonna have to break down and get the special toyota puller tool or is there another way that you guys have figured to make it easier.....Can I just use my standard gear puller in some unique way or something?
