Decided to go ahead and replace the rubber parts holding the front swaybar since they have gradually gotten scuzzier over time.
As usual I started thinking and decided that...oh...those few parts might cost $20-$30 or so...
No way...they want around $90 for the (2) rubber pieces that hold it on the frame in front and for the (2) metal "sleeves" and (4) front & back rubber parts that hold the ends of the bar.
I actually paid the local Toyota dealer $66 for the sleeves and 4 rubber parts for the ends (sleepwalking again?)....but have decided to just use the parts to get measurements and then make my own. 10 days to return them.
Sleeves will be made from steel tubing...rubber parts from several discs of rubber belting material. Projected cost...maybe $4-5 tops.
The 2 parts at front on the frame are AOK anyway.
Will post dimensions & pics when finished.
Toyota does it again........
The front rubber on the frame is in good condition on mine...though I do have them shimmed with some thin plywood...the rubber is OK.
It's the stuff on the ends of the bars that is getting loose with mine.
