So, I finally got to test out the 4wd in my '86 six speed. It works, but only in EL. Is that the way it's supposed to be or is their something wrong? I tried to put it into second, since first isn't syncronized, and it just died. Many thanks.
"It's my fault for knowing not what I should have known" ---AIC
Mac wrote:EL is only for 4wd mode
shifting from EL to first isn't possible.
there IS a syncro for first gear, but it only works at very very low speeds.
In 4wd, from a standing stop in snow, i shift from EL to 1st, to 2nd and so on. It blows the doors off of everyone even my friends impreza awd.
-1992 TCR10 Previa LE -Thanks Jetswim-
-1987 AL25 Tercel SR5 -Sold To Jetswim-
-2000 PL2000 Neon LE -Sold to spencersummerfield-
-1999 PL Neon SE -Stolen, recovered cut in half. R.I.P.-
-1987 AE86 Corolla GT-S Coupe - Sold (I want it back!)-
Working fine now. I guess it just needed some mud beneath it. Shifts through all the gears flawlessly. I did manage to almost get it stuck today. I sat there, in the mud, contemplating the walk back to my house should I not be able to get it out under it's own volition. Luckily, it never came to that.
Check to make sure all your tires are the same size. Having one tire in a different size on a Tercel 4WD can make life with the 4WD system a little interesting.
"And to see you're really only very small
and life flows on within you and without you." George Harrison
