(3E 150 12-valve, on feedback carburetor)
It has a lot of problems, basically hard to start when cold, and when idle in Park or Neutral, it idles and revs fine; but almost stalling when you shift to drive gears, as if it lacks power. Surging too, and the occasional misfire. I looked over the vacuum hoses, and found that almost all of them were plugged in the wrong places or something.. and went on one whole day YESTERDAY of tracerouting those damn vacuum hoses, following the vacuum hose routing chart on the hood.
Now i regret the stupidity that is me for not making a backup reference to the hoses' previous connections, beacause now, it constantly misfires, the engine heats up so fast that i smell hot oil most of the time (coolant temp only reaches halfway..) and it sputters and the occasional loud bang of a misfire.
The connections i corrected were the BVSV v-hose connections at the back of the engine (toward the firewall), the hoses to the VSVs relayed to the A/C actuator as well as the two VSVs with electrical connector/s on it, and a 3-way VSV (ports X, Y Z?), vacuum modulator (ports p,q r) EGR valve, HAC, & carburetor v-hose ports, both large and small. And the two lines to the distributor, which i don't know which is correct.
Pain of it is, this is my first car and i can't really afford getting a mechanic to do it for $200
ANY help for a total newbie in this task will be appreciated.. Thank You very much for any assistance.
*Maybe a proper vacuum routing for automatic trans with A/C will help greatly, though i think that's not the only problem..*
