distributor help
83toybeater
distributor help
Post by 83toybeater »
ok i think i found out why i have had such a hard time with drivabilty and performance on my 83. its a 4ac with a weber.
question
does anyone know if the dissy is a 2 stage distributor? where one of the ports runs off of manifold vac, and the other off throttle vac? and also what one does what?
i have always had vac going to the top port, today i realised that my dissy isnt even responding to vac advance.
please input needed asap, as im gona put a new dissy in tomarow
There are 2 and 3 port dists...only one is needed for advance. Just test the one you want to use to be sure it advances the plate?
83toybeater
ok i put the new dissy in today, well not new its probly 25 years old butanyways it works correctly.
i put a a vacuume tester up to the 2 ports on the new one, the top one advances it a little, the lower alot. me and the tech at my work agree that it is a 2 step adance distributor. the top one runs off of manifold vacuume, the bottom runs of throttle vac. based on how they move it makes perfect sense to me
can someone correct me if im wrong?
ps my old dissy both of them didnt advance it at all
Typrus
Post by Typrus »
Yup. One gets full mannie vac the other gets ported vac. The little vac port above the throttle plates I believe....
That upper port also runs the EGR thru the vac modulator?
83toybeater
it has a weber on it, where do i find throttle vac, the port on it seams to be manifold vac.
I think you want full manifold vac?
83toybeater
i need both, the manifold vac advances it once the car is started, throttle vac is for when you get on the throttle.
we put a vac tester to each of the ports, the top port only adv a little, the bottom advances alot, there fore top is manifold, bottom throttle
coming out of the weber is constant vac, so that leads me to belive its manifold.
Basically all you need is manifold vac advance at idle and centrifugal advance at higher speeds?
The R port (partial vac) is related to the emissions stuff...such as the EGR, etc?
83toybeater
what one is the R port?
