Lift with cherokee springs
Soutthpaw
Post by Soutthpaw »
Here is a pic of the front CV shaft with the lift, so definitely there is room to go higher
If I put new gas charged strut cartridges in then based on what I have read here I will gain about another 1/2 to 1 inch in the front. But no one had them in stock locally and wanted to see what it looked like so used the old ones.
1989 Toyota Van LE 4x4
1987 Toyota Parts Van 4x4
1981/2000 International S1724/4700 CrewCab T444e
1974 Wellcraft Airsolt (Boat)
ASE Master Auto Tech.
simon84
Post by simon84 »
I picked up a pair of Nissan pathfinder rear springs for my next tercel lift project. They look like they will go in the back no problem, may have to be shortened a little. I'll try to post when I get around to doing the mod. That may be a while tho.
SUterkel
Post by SUterkel »
i have an 84 with tj rear springs front and rear which are uncut. i simplly extend the the strut post up and was able to can 6" of lift in the front. the sway bar was an issue because it caused the camber to be way off. but with some modifications to it the cambe is is fine.
Gasoline Fumes
Post by Gasoline Fumes »
SUterkel wrote:i have an 84 with tj rear springs front and rear which are uncut. i simplly extend the the strut post up and was able to can 6" of lift in the front. the sway bar was an issue because it caused the camber to be way off. but with some modifications to it the cambe is is fine.
You need to post pictures! :o
Gotta watch the ends of the swaybars with a lift. They are made to take only so much angle before you will start to put a sideload on that thin end piece....which goes into a heat treated forged bar. Metal fatigue.
I wouldn't use poly bushings on the end...you'll need all the flex you can get at this joint. Think rubber?
SUterkel
Post by SUterkel »
i don't know how much stress there is. the sway bar had to be cut at the cent and extended about 5" the mounting braket tot the frame also has to me moved.
i will try to get pics up soon i will worn all thought they are not pretty nor is the terkel. i paid 40 bucks for it and it had been sitting in a field for 3 yrs.
Lollypop
Post by Lollypop »
6" lift on a Terc? This I gotta see. Almost sounds too good to be true. Not sure my heart can stand it.
=====Justin=====
1987 Tercel 2WD, 1983 Tercel 4WD
coltarms
Post by coltarms »
PICS PLEEEEEEEASEEEEEE!!!!!!!!!!!
El SR6
Pictures?
Post by El SR6 »
I want to see pictures too! Do a write up. I want to put some 28" Super Swampers on my Tercel!
Tercel4X4Fun
My tercel:: 83 Tercel SR5 4WD SW Sunroof
Re: Lift with cherokee springs
Post by Tercel4X4Fun »
Looking to lift my 83 Tercel 4x4 wagon.
Can someone sum up the blog in one new post to clarify the lift parts and process?
Plus, can anyone answer the alignment problem?
Thanks
Get OFF-ROAD in a 4WD Tercel SR5 T o d a y ! ! ! !
terkill
My tercel:: 1987 Toyota Tercel 4WD
Post by terkill »
dang this is an old thread, too bad the pictures dont work, that would be a cool sight to see.
